Old 01-19-2006, 11:54 PM   #1
billyr2.5
Member#: 53663
2011 WRX WR Blue
2000 Coupe, Sedona Red
Default 2002 wrx fuel pump in gc8?
putting a 2002 wrx fuel pump in a 2000 2.5rs...good idea or just Stupid?
billyr2.5 is offline   Reply With Quote
Old 01-21-2006, 01:59 AM   #2
billyr2.5
Member#: 53663
2011 WRX WR Blue
bump for any info
Old 01-21-2006, 02:04 AM   #3
t3hWIT
Member#: 58779
95 STi RA (rhd)
98 Tacoma (300k Club)
Good question. Wiring will almost definately have to be done, but thats not my specialty, I do wrenching. What kind of modifications do you have? The wrx fuel pump is usually reserved for boosting and engine swaps.
t3hWIT is offline   Reply With Quote
Old 01-21-2006, 02:42 AM   #4
billyr2.5
Member#: 53663
2011 WRX WR Blue
just normal bolt ons, intake, exhaust, intake manifold spacer, underdrive pulley, clutch, and kaaz close ratio gear set...but i am soon going to get cams and then eventually port and polish the heads
Old 01-21-2006, 02:43 AM   #5
Handsdown
Member#: 29355
even with cams the stock fuel system should be well within acceptable limits of handling the load. i've seen and heard of cars going many years without fuel problems even with more mods than you have listed.
not to say it's not worth it, but... it's not worth it.
Handsdown is offline   Reply With Quote
Old 01-21-2006, 02:47 AM   #6
2slofouru
Member#: 90539
I've got an 04 wrx pump running in my 95L with 98dohc engine and 2.25 exhaust with no problems. I soldered mine in. Didn't make the car run any better or worse than with the stock 1.8L pump, but I'm sure I saved some serious weight considering the stock L pump was about twice the size. That has to help my 0-60!
2slofouru is offline   Reply With Quote
Old 01-21-2006, 03:28 AM   #7
billyr2.5
Member#: 53663
2011 WRX WR Blue
did you have to tune the ecu to the rex fuel pump?
Old 01-21-2006, 03:57 AM   #8
2slofouru
Member#: 90539
I have the stock 1.8 ecu. I don't think there is enough extra volume to justify tuning by changing to the wrx pump. The fuel pressure regulator will dump the excess fuel if there is any.
Old 01-22-2006, 03:05 AM   #9
solbey11
Member#: 89234
Your ECM will recognize the added pressure in the fuel system. So in return it will reduce the dwell time of your fuel injectors to ensure you will still have the proper A/F mixture. And your fuel pressure regulator will bleed off most excess pressure.
solbey11 is offline   Reply With Quote
Old 01-22-2006, 11:40 AM   #10
2slofouru
Member#: 90539
I don't think the gc8 models have a fuel pressure sensor(at least mine and the others I've seen don't). The ecu only knows how much fuel is being spent by reading the o2 sensor, correct? I've never seen fuel pressure sensor wires in any of the ecu diagrams I've checked. Anyone else know?
Old 01-22-2006, 12:40 PM   #11
solbey11
Member#: 89234
Actually that's what I meant. I just read it again and it does sound like I meant it had a sensor. But you are right, from the A/F or O2 sensor, it determines if it's running the engine lean or rich.
2002 WRX Fuel pump. 2000 miles old mattjk Engine/Power/Exhaust 3 08-05-2009 11:58 PM
wrx fuel pump in 99rs??? beaun-nus Subaru Conversions 7 06-12-2007 08:39 PM
wrx fuel pump in 98 impreza L? rufracer Normally Aspirated Powertrain 6 04-08-2007 01:59 PM
sti fuel pump in gc8 body?? sith Subaru Conversions 2 06-24-2006 04:49 PM
WRX fuel pump in 98 RS? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-30-2004 11:56 AM
