Old 01-20-2006, 12:42 AM   #1
cornerbuddy28
Member#: 88976
Main Ingredients:
WRX motor, PPG's, me
Default 1.8 to EJ257: accessory compatibility
I'm gearing up to start an STi swap into my 95 Impreza L 1.8 and I am thinking about building up my own motor so I'm wondering if I should keep any of the stuff from the 1.8 to use on the sti. Is there anything I can or can't use from it. I don't mean the heads or internals or anything, but like the alternator, starter, water pump, oil pump, oil pan or anything else?
cornerbuddy28 is offline   Reply With Quote
Old 01-20-2006, 05:31 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Oil pump and Oil pan i'm going to say no. Alternator probably, it will bolt up but I don't know if the connections and power output is the same. Starter, not sure, but probably would work. Water pump is different on the turbo motors due to the headers. Your A/C is swapable.
But if you do the swap, try to get as much of that stuff from whatever motor you are going to buy...
Old 01-20-2006, 10:38 AM   #3
cornerbuddy28
Member#: 88976
Main Ingredients:
yea I would like to not have to use my old parts from the 1.8 but if I'm running low on money next summer when i do the build I just wanted to know what from the 1.8 I could use in a pinch. Also I'm ditching AC all together.
Old 01-20-2006, 11:09 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Starter cares about the tranny for the mounting. But you can use your starter if it's in decent condition. I would reuse the alternator. You will want a turbo oil pump and water pump, and oil pan.
Old 01-20-2006, 11:33 PM   #5
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
the starter was the same for the 1.8 and the 2.5, the 2.5 one actually broke and i'm using my old 1.8
STi-Nismo Dood is offline   Reply With Quote
1.8 to 2.5- problems going to non-OBDII ECU? beachbum Normally Aspirated Powertrain 8 06-27-2002 10:14 AM
1.8 L performance part compatibility? bh2 Newbies & FAQs 3 05-31-2002 09:25 PM
1.8 to 2.2 engine swap 93preza Normally Aspirated Powertrain 3 10-14-2001 03:13 PM
1.8 to 2.2 swap, same harness??? HYDCSX400 Normally Aspirated Powertrain 3 05-15-2001 07:54 PM
1.8 to STi 2.0 swap... need some help. wagman01 General Forum Archive 5 02-21-2001 09:57 PM
