Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 01-20-2006, 10:16 AM   #1
Member#: 80681
2003 Impreza WRX
Platinum Silver
Default curious
i have been reading threads about people uping the size of there rims and wider tires and there speedometer is going to be off. and rpms at different speeds will be different than stock tires/ rims. what is that all about?
hockeygm is offline   Reply With Quote
Old 01-20-2006, 10:34 AM   #2
Member#: 93193
'03 325iT
Um, different sized tires will have different circumferences which will change the number of revolutions required to cover one mile.
Here's a calculator that will help with determining tire diameter.
Actually, I like this one better as it will show the speedometer difference.
VpointVick is offline   Reply With Quote
Old 01-20-2006, 11:01 AM   #3
Member#: 47769
What the heck are you trying to say??? Please reformat that in readable English.
subieworx is offline   Reply With Quote
Old 01-20-2006, 12:04 PM   #4
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
The closest sized tires to go with in 17" would be a 225/45.(The speedo would only be off by about .3 mph) In 18" you would want a 225/40.
Pete Holt is offline   Reply With Quote
Old 01-20-2006, 01:40 PM   #5
Member#: 57830
The width has nothing to do with it. It's the overall circumference (or diameter) that affects the speedo and odo.
The speedo/odo system is like any other system of gears. When you change the size of one of the gears, the speed at which the other gears turn changes. Increasing or decreasing the size of the wheel is like changing the size of a gear, making the gauges reading the gears further up the line read differently.
Most car's speedo/odo's are geared to run a little fast (you think you are going faster than you actually are) with brand new OEM tires. My TS came with 195/60r15's which are about 24.1" in diameter. My speedo and odo were about 4% off. When my speedo read 100kmph I was actually doing 96kmph (or at a reading 50mph I was doing 48.5mph). For every 1000km my odo said I was putting on the car I was actually only travelling 960km. When I switched to 205/55r16's, which are 24.9" in diameter my speedo and odo were much closer to being correct.
Howl is offline   Reply With Quote
curious question christoph1371 Bay Area Impreza Club Forum -- BAIC 21 04-16-2001 12:24 AM
