Old 01-20-2006, 02:14 PM   #1
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Default Element STI Hydra 678 HP All Boost!
What can I say, the dyno speaks for itself: 678 whp and 634 ft/lbs of torque all turbo using VP C16 fuel.
The dyno is a Dynapack 3500 owned by Slow Motion in Ohio.
This STI had once before been tuned by me to just under 600 whp and ran a quarter mile time of 11.0 @ 135.5 mph without N20. I feel the Dynajet I normally use reads on the low side or the car simply picked up a little more power in the real world. Fast forward a few months and some new modifications were performed. The heads and block were decked to get a better seal on the head gasket. I requested that the thinnest head gasket be used so we could benefit from the slight increase in compression ratio. An unequal length header was also installed, along with a fresh GT35R 1.06 turbocharger. The engine is an Axis Power Racing engine but still uses the stock block and the heads are ported with larger valves and 272 cams.
Here’s a quick list of mods:
Axis Power Racing STI engine (rods, pistons, stock block)
Axis Power Racing STI heads (bigger valves, porting, springs, 272 cams, no AVCS)
Element STI Hydra EMS (custom tuned by Element)
1000cc injectors
Aeromotive Fuel pump
Unequal length header
GT35R 1.06 AR
Here’s the interesting part, with those modifications, 2 psi more boost (29.2 vs 27 absolute), and more tuning, we hit about 648 whp. So where did the extra power come from? Removing the intake completely and bypassing the power steering pump netted 30 whp more at this power level. Unfortunately we did not test these two items separately but I suspect the majority of the gain was from the removal of the air filter.
Tuning was what I consider moderately aggressive but at this power level we didn’t want to push beyond this point. The AFR was 12:1, boost was 29.2 psi (absolute), and ignition timing peaked at 26 degrees. The 1000cc injectors hit a peak of 98% duty cycle.
Sorry guys but at this point this car will never see the drag strip as it is and has been for sale. Alex wanted me to retune the car so the new and lucky owner wouldn’t have to. Here is a link to the car's for sale page which also lists all modifications: http://forums.nasioc.com/forums/showthread.php?t=914934
Let the flaming commence
Thanks,
Phil
Element Tuning
(240)246.0302
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 01-20-2006, 02:21 PM   #2
03twrx
Member#: 73737
I've travled 500 mil
es to give you my seed
Dayum! It goes right up there doesnt it.
03twrx is offline   Reply With Quote
Old 01-20-2006, 02:22 PM   #3
pux888
Member#: 8356
02 STi swap
12 WRX limited
All I have to say is wow!
pux888 is offline   Reply With Quote
Old 01-20-2006, 02:23 PM   #4
checque
Member#: 68562
RIP Edwin
Either he's a dumb bastard or is building a PMSing mother of all monsters. <--Which means "Damn, this guy can build a sick car!"
Oh yeah, that 50whp at 2k is AWESOME! I'd drive everywhere doing 2k! <--Which is a joke, if you didn't get it, kill yourself.
Damn, he's buying a house instead of a new car . . . <--Which was after I read the other thread.
checque is offline   Reply With Quote
Old 01-20-2006, 04:10 PM   #5
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
AEM Factory Trained Tuner
Congratulation thats a killer combination good luck to the future owner.
Good job guys
Gadiel
Gadiel is offline   Reply With Quote
Old 01-20-2006, 04:36 PM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Can't wait to see this car tomorrow at the dyno day.....get some numbers on Buschur Racing's Mustang Dyno. Can I please, please, please have a ride :Puppydogeyes:
SloRice is offline   Reply With Quote
Old 01-20-2006, 04:37 PM   #7
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Phil, i think you left out this car is running our kit..
Alex, congrats on the new found power. Phil did an amazing job tuning the car.. I would love to see your car with a 40r.
Good luck with the sale.
Dave-
Kingpin is offline   Reply With Quote
Old 01-20-2006, 04:41 PM   #8
spoolindc2
Member#: 72972
2003 WRX Stage 2 HKS
nice job, man i wish i could make that kind of power w/ my car...
spoolindc2 is offline   Reply With Quote
Old 01-20-2006, 04:41 PM   #9
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
Sweet Jeebas!!!!
SubyDuz is offline   Reply With Quote
Old 01-20-2006, 04:46 PM   #10
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
WOW def bump up that redline. at like 7200 it is at like around 450wtq and 630ish whp still haha
Caplin 2.5 is offline   Reply With Quote
Old 01-20-2006, 04:47 PM   #11
Element Tuning
Member#: 54918
673 WHP Element
Originally Posted by Caplin 2.5
WOW def bump up that redline. at like 7200 it is at like around 450whp still haha
The rev limit of the car is actually higher but we decided to only dyno to 7200 rpm (by the way this was 7600 rpm on the tachometer?) as the car is for sale. We also cooled down the car before each pull to reduce stress as much as possible. As you can see though a lack of high RPM power is not the reason for cutting the rpm short.
Thanks,
Phil
Old 01-20-2006, 04:50 PM   #12
Element Tuning
Member#: 54918
673 WHP Element
Good job guys
Gadiel
Gadiel,
Thanks. This is the car I had mentioned in our conversation about converting the camshaft pickup of the STI to the camshaft sprocket pickup of the WRX for use with JUN 272 cams when using the Hydra EMS. Give me a call if you need some guidance.
Thanks,
Phil
Old 01-20-2006, 07:58 PM   #13
Caplin 2.5
Member#: 71203
2005 2.5rs
Thanks,
Phil
Any pics of the car? How much you guys sellin it for?
Old 01-20-2006, 10:16 PM   #14
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
HEY! thats some power
lets see those 10 sec slips...
LatentWagen is online now   Reply With Quote
Old 01-21-2006, 02:08 AM   #15
spooln04
Member#: 85421
92 EG all mota
Sweet! video please...
spooln04 is offline   Reply With Quote
Old 01-21-2006, 02:29 AM   #16
InfamousDX
Member#: 25413
wow.... sick ass car. seriously wish i could afford to buy it... instead of trying to dupe it.
Old 01-21-2006, 09:00 AM   #17
evilimpdrvr
Member#: 94169
2005 wrx
Dude when you grow up your understand that somethings are more important in life than having a fast car. I would sell a car like this to have a house. In the long run the house will buy another car and i bet it will.
Thats why i bought my house first then went for the car.
evilimpdrvr is offline   Reply With Quote
Old 01-21-2006, 10:08 AM   #18
Element Tuning
Member#: 54918
673 WHP Element
I shouldn’t even dignify this with a response but you're way off base as I’m sure others are also. Often these huge power cars skew the way the graph looks and you think, "Wow that car has no bottom end power." Well when you see a stock STI graph overlaid onto this one you'll see that the small sacrifice below 4200 rpm is well worth it for the area under the curve you gain after 4500 rpm in both torque and HP. This was taken from a stock STI dynoed on a Dynapack 3000.
By the way a stock STI also makes about 50 hp at 2K rpm.
Phil
Old 01-21-2006, 11:46 AM   #19
LatentWagen
Member#: 50315
I shouldn’t even dignify this with a response but you're way off base as I’m sure others are also. ...the small sacrifice below 4200 rpm is well worth it for the area under the curve you gain after 4500 rpm in both torque and HP...
Phil
while the NUMBERS may indicate a similarity between 50hp @ 2krpm on a 1.06 gt35r, and 50hp @ 2krpm on a vf39, there really is no comparison. as i said before, this setup is sick. but lets not say that its going to be as responsive/powerful in the low end as a vf39. just cause the dyno says so, doesn't make it the truth. there is NO comparison between how a vf39 sti feels before 4000, and how this car feels before 4000, lets be honest.
Old 01-21-2006, 11:56 AM   #20
mrwrx2002
Member#: 59085
World Rally Blue Pearl
wow that is an incredible car
mrwrx2002 is offline   Reply With Quote
Old 01-21-2006, 12:06 PM   #21
nuhga
Member#: 80770
2005 v7 spec-c
i dont think he ever said that it feels the same... infact he said little 'sacrifice' on low end is well worth it.
nuhga is offline   Reply With Quote
Old 01-21-2006, 12:08 PM   #22
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
amazing numbers phil.
StealthWRX is offline   Reply With Quote
Old 01-21-2006, 12:18 PM   #23
ranger5oh
Member#: 77752
5Sti 2005 Sti
impressive, but I am not a fan of this 4000rom "wall of death" tuning... id like to see it a little wider for street use, but for a drag car, its pretty cool
ranger5oh is offline   Reply With Quote
Old 01-21-2006, 12:32 PM   #24
adamrmr
Member#: 4338
STi T3/To4e 433WTQ
tuned by Clark
Great #'s!!
adamrmr is offline   Reply With Quote
Old 01-21-2006, 12:33 PM   #25
Newbie Subie
Member#: 20214
07 Acura RDX
390WHP no more
Awesome numbers Phil Congrats!
And you are the Hydra tuning man. I wont let anyone else touch my ECU.
Newbie Subie is offline   Reply With Quote
Accept no compromises -- Element Tuning Hydra EMS and HOA 3-Port Boost Solenoids! WorldOne Engine Management 144 11-09-2009 01:17 PM
04 STi Element Tuning Hydra Nemesis 2.5 berserksti Engine/Power/Exhaust 11 10-10-2007 10:54 PM
Element, Axis, Kingpin, sti daily driver goes 10.9 & 138mph - all boost 700hp Proven Power Bragging 115 04-16-2006 06:41 PM
Gadiel own STI [email protected] All boost no Nos USDm STI full weight Gadiel Proven Power Bragging 64 02-01-2006 10:55 AM
Element STI Hydra Data Log Element Tuning Other Engine Management 9 01-19-2005 12:01 PM
