Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 01-20-2006, 10:55 PM   #1
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
Default When you go stage 2...
when you go cobb ap stg. 2, do you reset the ecu and then put the stg. 2 mod on or you don't have to reset the ecu at all?
sizzflair is offline   Reply With Quote
Old 01-20-2006, 10:59 PM   #2
Member#: 90977
'16 STi
you should just be able to load the stage 2 base map once you have your mods on, and be good to go. the ecu will learn from that point.
tmt502 is offline   Reply With Quote
Old 01-20-2006, 11:02 PM   #3
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
If you flash it as a basemap (which you should), it resets the learning portion of the ECU in the process anyways.
mcowger is offline   Reply With Quote
How soon should you get tuned when your at stage 2? bullysonwrx Newbies & FAQs 20 05-25-2010 12:17 PM
When to Go Stage 2? fbi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 03-12-2010 05:26 AM
Can you go stage 2 with the stock axleback? Padge AccessPort 8 03-17-2008 03:19 PM
Careful when you go after those Militants; you don't know who you may offend quantum Off-Topic 19 09-29-2005 11:32 AM
do you put you feet up on the stall door when you go #2? kbcr3 Off-Topic 34 06-16-2005 02:35 PM
