05-15-2001, 01:29 PM | #1 |
Member#: 5235
Vehicle:'98 Legacy GT w/ full-Nelson intake |
spring rates: stock/whiteline???
OK... so through my searching I have found the following spring rates:
Stock RS - F157 / R149 Whiteline Select - F190 / R150-170 does anyone know what the 97-99 Legacy GT spring rates are?? and if the above ##'s are correct... I assume the GT would have greater rates than the RS due to the extra ~250lbs. If the Whitelines are 190/150-170 ... that isn't much more than stock, right? people say they are stiff - and I don't want something too stiff... but they also seem like the only choice for sub 1" drop comments, sugestions?? thanks - Chad
05-15-2001, 04:03 PM | #2 |
Member#: 5211
SWIC
Vehicle:2007 Outback XT Ltd. Diamond Gray Metallic |
Chad,
Here is a direct quote from Whiteline RE their spring rates: "All our coils are about 25-30% stiffer than the original springs." Hope that helps, Doug |
05-15-2001, 05:47 PM | #3 |
Member#: 2609
Vehicle:98 BK-GT White '97 SVX Ebony Pearl |
I assume those WhiteLine numbers are for the Impreza application? I'm in the process of ordering some "wagon-specific" Select springs, and assume the Legacy application to be as stated "25-30% over stock" with minimal drop. Dale Teague may be able to give you actual ratings.
<FONT face="Comic Sans MS">Glenn O</FONT f> |
05-16-2001, 10:28 AM | #4 |
Member#: 5235
Thanks for the input... does anyone have Dale's email addy?
and - does anyone have experience running the Select springs? I have read some reviews, although a limited number of them, and the consensus is that the Whitelines are stiffer than the Eibachs - and comparable to the H&R's, but with less drop than either. (if I remember correctly) anyway - I have AGX's sitting in my closet, and I "think" I want some springs, as it has been advised not to run AGX's with stock springs, and I want the 1" drop for looks... I just want to do this once, and don't want to dammage my kidneys or anything so I am trying to be as informed as possible thanks again -Chad |
05-16-2001, 03:07 PM | #5 |
Member#: 5211
SWIC
When I asked Whiteline how stiff the springs are (and got the response I posted above), I was inquiring about springs for a Legacy Wagon not an Impreza.
Doug |
TiC SST/AST Coil-Overs w/ AUTOX Spring Rates: 8K/7K | STFU STi | Car Part Reviews | 3 | 03-16-2008 11:54 PM |
TiC SST/AST Coil-Overs w/ AUTOX Spring Rates: 8K/7K | STFU STi | Car Part Reviews | 0 | 03-12-2008 07:52 PM |
Official word on STI Spring rates: look here | nhluhr | Brakes, Steering & Suspension | 39 | 09-21-2004 05:18 PM |
Spring Rates: Prodrive and Eibach? | SoLiDbReAkZ | Brakes, Steering & Suspension | 5 | 08-07-2002 01:21 PM |
H&R spring rates: Dubious info on Ravensblade? | dcw23x | Brakes, Steering & Suspension | 2 | 01-07-2002 08:43 AM |
