Old 01-21-2006, 01:41 PM   #1
solo2sti
Member#: 59440
2004 WRX Sti
wrb
Default changing spark plugs
Where do you access the plugs to change them?
solo2sti is offline   Reply With Quote
Old 01-21-2006, 05:46 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
2 on each side
Old 01-21-2006, 07:40 PM   #3
VIR EURORALLY
Member#: 53517
STi Outback STi
On the drivers side you can just remove the washer resevoir if your hands are small enough and you can get to both plugs and the coil packs. If you have larger hands just remove the battery as well. On the passenger side you can remove the intake and get to the plugs and coil packs.
VIR EURORALLY is offline   Reply With Quote
Old 01-22-2006, 09:30 AM   #4
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
I have a nice write up on it I found on another forum.... I have it at home if you want I can pm you. There really easy to get to.
JNUTZ is offline   Reply With Quote
Old 01-22-2006, 11:48 AM   #5
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
Changing spark plugs...need to change all 4? jester696 Service & Maintenance 6 12-22-2008 08:10 PM
Trying to change spark plugs - can't get socket on plug winston856 Service & Maintenance 5 03-18-2008 05:42 PM
changing spark plugs? racerwad Newbies & FAQs 7 10-23-2000 06:47 PM
When did everyone first change spark plugs? SubieRacer Technical Forum Archive 19 05-27-2000 07:38 PM
At what engine temp to change spark plugs?? Dan00RS Technical Forum Archive 5 05-12-2000 12:52 AM
