Old 09-16-2001, 09:00 PM   #1
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
Thumbs down Help! Strange noise from the back of the car.
Ack! Whenever I'm moving now (I'm convinced it's associated with the rear wheels rolling), it sounds like something is rubbing against something else. I hope it's just the tires, but it sounds more metallic. Last weekend I changed my tranny and diff fluids, could that be associated? Like maybe I didn't but enough diff fluid in and some the the parts are rubbing together. That wouldn't be good. Anybody have an idea what's happening?
Marc
Marc Sawaya is offline   Reply With Quote
Old 09-16-2001, 09:04 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
check your fluid levels asap, and make sure you used the correct fluids
could also be the feared subaru wheel bearing, still under warranty?
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 09-17-2001, 12:04 PM   #3
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
bump- any more ideas?
Old 09-17-2001, 12:08 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Question
brakes... rear brakes.... check em...
and be certain that your tire is not rubbing...
stock suspension?
stock tires??
j.
www.subiegal.com
Old 09-17-2001, 12:42 PM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Have you been in gravel at all? Pick up a stone in the rear brake?
CosmoTheCat is offline   Reply With Quote
Old 09-17-2001, 03:23 PM   #6
aov
Member#: 7193
MY02 WRX
I think you answered your own question, especially if you have checked some of the other things mentioned above. From what I understand it is very important to use the correct oils and to make sure you fill to the correct level.
Hope you sort it out,
-Anders
aov is offline   Reply With Quote
Old 09-17-2001, 03:29 PM   #7
wilddave1
Member#: 9101
2005 Jeep Wrangler
Aprilia Tuono
I have picked up rocks several times inbetween my front disk and dust shield. I would check this first. Have you driven on fresh tarmac or tar covered gravel recently?
wilddave1 is offline   Reply With Quote
Old 09-17-2001, 07:57 PM   #8
N/A
Member#: 133
TBA TBA
TBA
Well if you really want to track down the problem on your own then get the car on a lift or jack stands so that all four are off the ground. Grab the top and bottom of the tires and give them a wiggle. If there is some play in the bearing you will notice it by the wheel rocking in and out. Check the brake pads to see if you picked up a rock. If not then see if you have a warped rotor or if the caliper needs rebuilding. If the caliper freezes up it will do it either at the pistons or at the posts that allow for equal pressure front and rear. If the calipers freeze up they will make a dragging sound. The rear diff shouldn't go out unless you've really abused it or you didn't use the right fluid/not filled up enough. All of these are easy to check for and should take you more then 20min to do. If you have a bad caliper then order a rebuild kit and drop me an email. I can give you a walk through on how to rebuild them. For the bearing you had better take that to the dealership.
N/A is offline   Reply With Quote
Old 09-18-2001, 11:10 AM   #9
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
I'm going out to check for something in the brakes now, otherwise I'm just gonna take it to the local dealer because I don't have the tools to check the diff fluid or put the car up on stands. I kind of hope it's the wheel bearing thing, because I really don't want the diff to be messed up, especially if it's my fault! I'm pretty sure I did everything right, and I used the same fluid as Fishguy because he did his at the same time. Are you getting this noise, Fishy?
Old 09-18-2001, 10:22 PM   #10
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
Well, I took it to the dealer today (back to Tri-State, where NESIC had a mini-meet last weekend), and they said it's the wheel bearing. That's sort of a relief, because it means it's not my fault, plus it's not going to cost me anything. And I didn't screw up my diff.
I'm taking it in on Thursday, so hopefully that'll fix everything. Until then, I'm not driving it, I don't want to risk anything.
Old 09-18-2001, 10:43 PM   #11
tsfxRS
Member#: 8442
98 2.5 RS
blur of red
Marc
If it doesnt fix everything I was told my "bump" was a broken or loose strut mount. My friend had a 2000 RS and he had the same sound as i do. Let us know for sure what it turns out to be.
tsfxRS is offline   Reply With Quote
Old 09-20-2001, 10:16 AM   #12
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
Well, I just got it back from the dealer and it seems fixed! No more noise, so I guess it was the wheel bearing. I'm glad that's over with. I got an alignment too, because I'm sure I needed one. So far 24k miles on the car, and the only "repair" it's been in for was this and the recalled O2 sensor, and the sensor wasn't even giving me problems. I just had it replaced as a precautionary measure. Here's to many more problem-free miles!!
Thanks for the help guys,
Marc
Old 09-20-2001, 02:41 PM   #13
Kalins1
Member#: 484
2003 Baja
Custom Silver and Red
Marc,
Hello. Glad to hear it's fixed!
What exactly was the noise it was making? Was it a squeaking noise or a "rump...rump...rump" noise?? Did it sound like the squeal that the brakes normally make when you are applying them?
Thanks!
Sean
Kalins1 is offline   Reply With Quote
Old 09-21-2001, 09:48 AM   #14
Kalins1
Member#: 484
2003 Baja
TTT
Old 09-21-2001, 12:35 PM   #15
Marc Sawaya
Member#: 3539
MY00 BRP GM6 5MT
Out There Somewhere
No, it was a steady, metallic "rubbing noise", almost like something was dragging on the ground. You could start to hear it at around 20 mph, and it got louder on the highway. It was very audible, you could definitely tell something was wrong.
Old 09-21-2001, 03:22 PM   #16
Kalins1
Member#: 484
2003 Baja
Phew...thanks. That is definitely not the sound that mine is making. I think I have out of round drums.
Sean
help me to get off the sticker in the back of the car dawhim Interior & Exterior Modification 8 08-08-2005 07:27 PM
Startup noise; Sounds like a bunch of stuff flowing from the back of my car to front Neo Maikeru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2004 12:21 AM
what is the name of the time machine that is on the back of the car crowbar Off-Topic 17 10-24-2004 08:30 PM
Squeaking sound coming from the back of the car hoodyap Brakes, Steering & Suspension 1 06-16-2004 11:23 AM
Strange noise in the back of my car... fellfrosch7 Tri-State Area Forum 5 01-24-2002 05:28 PM
