Old 01-21-2006, 09:49 PM   #1
vipernj
Member#: 86854
2004 fx35 02 Z06
Default For those of you with Forge BOV's, need help, what spring are you using?
hey all. Just got mine yesterday and put it on.. sounds nice, but the spring it came with seemed too tight. I put the smallest looking spring in and it seems to be working ok, but it does feel a little loose as well. Since there is no adjustment screw... these are the other springs I have, and I dont knwo which one to use...
Also, what are these spacers for... Since I have the smallest spring in, can I use one of these spacers to help out just a little? Thanks
vipernj is offline   Reply With Quote
Old 01-21-2006, 10:45 PM   #2
vipernj
Member#: 86854
2004 fx35 02 Z06
anyone?
Old 01-21-2006, 11:26 PM   #3
tdxflex
Member#: 13634
Green: 5-15 PSI
Yellow: 15-23 PSI
Blue: 23-30 PSI
Red: 30 + PSI
The discs are used the same way an adjustment screw is, to put pre-load on the springs if you need to fine tune between suggested rates.
tdxflex is offline   Reply With Quote
Old 01-21-2006, 11:35 PM   #4
Kitt
Member#: 24621
2006 Legacy GT
2011 Forester XT
I use the blue spring but get compressor surge with anything below full boost besides that the car seems to run the best with this particular spring. I get no compressor surge with the yellow spring but it feels like the car spools slower.
Kitt is offline   Reply With Quote
Old 01-21-2006, 11:55 PM   #5
vipernj
Member#: 86854
2004 fx35 02 Z06
ooo, ok... from the pics i took i have the green spring in there.. it seems to be ok, but I do think its too loose, maybe one of those discs will fix that... otherwise ill try and switch to the yellow spring and see if that helps
Shift linkage bushings for those of us with a return spring? Patrick Olsen Transmission (AT/MT) & Driveline 13 10-14-2007 09:03 PM
What springs are you running in your GC swap? John2.5RS Subaru Conversions 13 06-15-2006 04:44 PM
For those going to the Chi-town auto show: What automaker will you scorn the most??? Draven235 Mid West Subaru Owners Club Forum -- MWSOC 40 02-28-2006 05:21 PM
For those of you w/ the 2.5 shortblock, what turbo are you running? blue04 Factory 2.0L Turbo Powertrain 26 10-22-2005 02:59 PM
AGX/KONI: What Springs Are You Using? sandiegowrx Brakes, Steering & Suspension 10 11-11-2003 12:48 AM
Message Board Statistics All times are GMT -4. The time now is 10:49 PM.
