Notices
Old 01-21-2006, 11:12 PM   #1
Hagwag02
Member#: 63445
2002 WRX Wagon
Default Power lock/window trim removal
I've removed the screw in the door handle and the trim piece slides around, but do I pull the trim straight up, slide the piece backwards, or pull the opening apart somehow? Not knowing how it fits makes it hard to not break something.
I am assuming the piece can be removed without taking off the entire door panel. At least that's what the manual indicates.
Thanks.
Hagwag02 is offline   Reply With Quote
Old 01-22-2006, 10:11 AM   #2
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
you don't need to remove the screw. the trim around the handle actually pops off. it has four little clips 2 on top and 2 on the bottom. carefully pry on the trim from the inside of the handle to minimize scratching or dammage.
if you don't have the right tools, you can also pop it off by pulling on the door card (once all the other screws are removed and pops are loose)
thedaddyb is offline   Reply With Quote
Old 01-22-2006, 01:12 PM   #3
Hagwag02
Member#: 63445
2002 WRX Wagon
That was going to be my other question. Thanks.
I used the wrong word when I wrote "handle". What about the trim piece with the grab hole and power window/lock buttons?
Old 01-22-2006, 06:07 PM   #4
cMags
Member#: 88668
'05 Outback Sport
5MT - Regal Blue / Grey
Outback Sport
That one you do have to remove the screw in the bottom of the pull handle, then theres only one clip up front - the rest is all friction-fit. Pops right out but obviously has wiring harnesses attached so you'll only get it few inches away...
cMags is offline   Reply With Quote
Old 01-22-2006, 06:41 PM   #5
Hagwag02
Member#: 63445
2002 WRX Wagon
That's what I had been hoping for.
Thanks to both.
FS: Window Switch/door lock and trim mrbob1983 Interior/Dressup/Audio & Security 7 12-18-2009 09:29 AM
WTB: sti or wrx shifter trim bazel ,door handles,power locks trim 05-07 ghostrr NWIC Private Classifieds 1 02-03-2008 06:50 PM
WTB: sti or wrx shifter trim bazel ,door handles,power locks trim 05-07 ghostrr Private 'Wanted' Classifieds 0 02-03-2008 12:43 PM
2K Legacy Outback Power Locks, Windows & Driver Side Seat Issue gusto Electrical & Lighting 1 06-03-2005 12:29 PM
No Power locks, windows, and backlighting. joshuagore Interior & Exterior Modification 6 04-10-2005 11:45 PM
