Old 01-22-2006, 01:23 AM   #1
B16A2NR
Member#: 88676
Default Questions about swapping ECUTEK ECU's
I am curious as to how much each ECUTEK reflashed ecu effects each car differently.
For example I'm considering trading my stock turbo, injectors, and ECU for a VF22, Pinks, and Harman tuned ECUTEK. We both have turbobacks, uppipes, and blitz intakes. But I happen to have a slightly larger TMIC (His: Sti, Mine: BPM) and a lightweight pulley. Is this difference in parts enough to give me bad air fuel readings? Or am I just worrying about minor parts that won't really matter in the tune.
Something in the back of my mind is saying that even with identical mods each car will react differently to a tuned ECU hopefully not enough to be damaging to the engine. Am I right?
B16A2NR is offline   Reply With Quote
Old 01-22-2006, 07:09 PM   #2
B16A2NR
Member#: 88676
Bump for some input
Old 01-22-2006, 09:01 PM   #3
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Even the same parts on a different engine may yield different results.
Depending on how aggressive the tune is, it may cause problems due to these variations. I guess you could try it, get some datalogs and see how things look. I would at least plan for the case where you may need a retune. Maybe you will get lucky, though.
Mike
crazymikie is offline   Reply With Quote
Old 01-22-2006, 09:43 PM   #4
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
Also take into fact, mileage on the car and maintenence. His engine may have more wear and tear, or vise versa.
pudnana is offline   Reply With Quote
Questions about my ecutek ecu epaplia Engine Management & Tuning 2 02-28-2007 08:12 PM
Quick question about the ECUtek simpwrx02 Engine Management & Tuning 2 12-13-2005 01:13 PM
Question about utec/ecutek SupraScooby Engine Management & Tuning 5 08-14-2005 06:07 PM
Noob AP question about 04' 05' ECU's M8 Engine Management & Tuning 11 06-19-2005 10:36 PM
Question about swapping in JDM EJ20 turbo engine and gasoline requirements edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2001 11:39 AM
