Old 01-22-2006, 12:25 PM   #1
USMARINE24M
Member#: 42077
98RS 98 JDM EJ20
Default td04 vs td05
I've got a 98 jdm forrester turbo conversion in my RS and the stock turbo is a td04. I can buy a TD05 cheap, and i was wondering if it would be an upgrade compared to the TD04.. i have bigger injectors that can be put in and already got the walbro.
thanks
edit.. dammit i guess i can't change my typo in the topic.. oops
USMARINE24M is offline   Reply With Quote
Old 01-22-2006, 04:57 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Yes its an upgrade, check the EJ20T forum. It will require tuning too of course.
Old 01-22-2006, 05:33 PM   #3
USMARINE24M
Member#: 42077
98RS 98 JDM EJ20
yeah i'm looking into engine management as well, but unsure of what to get or what will work
Old 01-22-2006, 09:19 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah but its not a bolt on affair it has to be converted to front entry
td04 -360cfm at 1 bar
td05 -505cfm at 1 bar
so yes going to need injectors and EM
Old 01-22-2006, 11:01 PM   #5
USMARINE24M
Member#: 42077
98RS 98 JDM EJ20
yeah i found out that pre 96 had the 90 degree elbow on intake side, but i can machine it to fix that. What kind of engine management would be good for jdms?
Old 01-23-2006, 10:52 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
is a 98 a ej205?..i really don't know
if its a 205 you might be able to get it ecutek'd other wise you are looking at standalones or piggybacks
td05 18g vs. td05 20g? stg2wgn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 46 04-14-2009 10:00 PM
??td05 8cm18g vs. td05 7cm18g vs. td06 18g?? rexspeedmaster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-16-2007 11:31 PM
vf39 vs td05 DRNWAGN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-27-2007 12:59 PM
vf22 vs TD05 18g? G-See Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 10-19-2005 03:43 PM
Monster Ported VF34 vs. TD05 16g? RyKling Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-11-2003 01:26 PM
