#1 |
Member#: 97644
Vehicle:2006 WRX Black |
i recently got an ap.
i was able to load my base map no problem. how do i load real time maps (the vallet and anti theft)? do i still need to connect the green test wires underneith column or do i just plug in and go to switch map. car on or car off. ignition on or off. there werent any instructions sorry for spelling
#2 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
Just go plug it in - no connectors.
However, there ARE insutrctions on Cobb's website... |
#3 |
Member#: 97644
I found the instructions thanks.
What map do I switch to if: I loaded my stage 2 93 base map. Than I load the real time vallet map. To load back to stage 2 93 do I than pick the realtime stage 2 93 map? I only ask becasue I know there are subtle differences between the realtime and base stage 2 maps. |
#4 |
Member#: 89071
SWIC
Vehicle:2000 Blue 2.5 RS 2004 Java WRX |
You can switch back to the 93 stage 2 map, but also, as I believe it, you can reset the ECU and it will go to the base map stage 2 and let your car learn. The real time map is essentially a map loaded to the portion of your ecu that does the learning.
| Thread Tools | |
| Display Modes | |
| TurboXS Universal UTEC Remote Map Switch UTEC-SWITCH | monSTIer | Engine/Power/Exhaust | 9 | 09-01-2008 12:39 PM |
| 04-06 sti Utec w/ map switch, gm 3 bar map sensor for speed density & tatrix cable | methaddict | Engine/Power/Exhaust | 26 | 07-12-2008 12:47 AM |
| FS (NY): TurboXS UTEC Delta v03 + TXS 4BAR MAP Sensor + Remote Map Switch | bbong | Engine/Power/Exhaust | 5 | 04-08-2008 05:46 PM |
| STI UTEC with TXS map sensor and map switch | bgod | Engine/Power/Exhaust | 3 | 09-06-2007 10:22 PM |
| Can I use an LED switch for XEDE map switch? | djoye | Electrical & Lighting | 0 | 09-02-2005 04:30 PM |
