Old 01-22-2006, 04:33 PM   #1
aspera
Member#: 7879
Default EJ20 height, width, length? Frame rail width?
I own a '91 MR2 and a WRX...and after a while I was thinking the impossible. So I measured. It turns out that the frunk (FRont trUNK) on the MR2 is about the same width as the Impreza framerail-to-framerail. It also looks like there is plenty of room front-to-back if the sheetmetal behind the radiator is cut out.
The center tunnel on the MR2 looks about large enough for the WRX 5-speed, with the exception of the 'gate' between the frunk and the tunnel.
Does anybody know where I could find dimensional data for the WRX like this?
http://www.mr2-tech.com/bgb/mechanical/volume2/body.htm
Click "body dimensions".
If anybody else is interested in this the WRX wagon width, front track, and rear track are almost identical. Wheelbase is about 4" shorter on the MR2, I think.
Specifically, I'm looking for engine width, length, and height. Frame rail width would also help.
aspera is offline   Reply With Quote
Old 01-23-2006, 03:48 AM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
i have a longblock on a stand, if you would post the dimenssions you wanted (like a diagram of crude sorts) i could take the measuring tape to it.
youll have to run a porsche gearbox if u rearmount the motor. or you'll have 5 reverse gears :P
swapstar is offline   Reply With Quote
Old 01-23-2006, 10:30 AM   #3
aspera
Member#: 7879
No Porsche gearbox for an AWD MR2.
I'm just curious to see how much effort it would take. From what I've seen, the engine could be made to fit in RWD form, but it would take extra work to make it AWD.
The good news is that it looks like the MR2 shares similar framerail to framerail width and that the WRX subframe (which supports almost everything) could nearly be bolted on with 4 bolts. The MR2 gas tank is in the center tunnel. By using a fuel cell in another location, the tunnel would become a transmission tunnel. Plenty of room for the exhaust as well.
By making the frunk area into an engine bay, the original engine bay can be used for other things. Fuel cell, muffler, radiator, intercooler?, turbo?, etc could all be mounted there.
There are only a few things in the frunk, but they need to be moved. 1) the battery. 2) the brake master cylinder/booster/lines 3) steering shaft
Engine width at the front of the EJ20 is the widest. That might be a problem. The EJ20 might be too tall, but I'd almost want to leave the hood off anyway to scare the old folks.
My thoughts on the front suspension: Use the Subaru aluminum lower control arms. I wish that Subaru had mounted them entirely to the subframe, but they didn't. So, rear control arm mounts would have to be fabbed. Companies like Tein make coilovers with interchangeable bottom brackets. Screw a WRX bottom bracket onto MR2 coilovers. Voila! Hybrid struts. The WRX anti-sway bars don't mount to the struts like the MR2, so no problems.
Rear suspension: The difference in wheelbase is about 4 inches, I think. How long is the driveshaft on an automatic/STi? If you use the automatic driveshaft with the 5-speed, will that be enough? The MR2 rear suspension and subframe are damn heavy from what I understand. They were designed long, long ago. Keeping it all Subaru (or really Nissan), would be done by using the entire Impreza subframe.
Shifter: The MR2 uses a cable shifter. A hole would have to be cut for the WRX shifter.
Old 01-23-2006, 10:58 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well as opposed to it as i am
you might think about a turbo SOHC motor instead the size difference/weight is astounding maybe even the ej22t
i would guess you are looking at a custom lengthed drive shaft
Old 01-23-2006, 11:34 AM   #5
aspera
Member#: 7879
Not lengthened, shortened. The 'sexy' MR2 has a shorter wheelbase. 99.4" for the WRX, 91" for the original Mk1 MR2, 94.5" for the Mk2 MR2, and 96.5" for the MR2 Spyder.
4.9" shoter.
Why would you be so opposed to a low-slung 2-door STi? Is it the pop-up headlights?
The MR2 might be one of the only cars that a Subaru drivetrain can be swapped into. Most other cars don't have the width in between the front frame rails...I don't think. The MR2 also has that huge tunnel in the car, and is already a RWD car.
The Ford Focus has been converted to AWD for rally, and one has also been Cobra-fied. That would be the only other candidate I can think of.
Old 01-23-2006, 12:11 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
oh i think its cool
just has some obsticles
Old 01-23-2006, 04:01 PM   #7
moss
Member#: 10197
Wouldn't this totally screw up the handling characteristics of the MR2?
moss is offline   Reply With Quote
Old 01-23-2006, 04:30 PM   #8
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
ahh. the frunk. was thinking about you merging the bay and the Runk.
tell me waht to measue, and i will. motor is siting on a stand
Old 01-23-2006, 04:39 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
this swap would be pretty nuts...do it...of course mid engine is cooler...don't even worry about the AWD...
Deck Height/Quench Height/Rod length MartinSTi05 Built Motor Discussion 32 04-05-2011 09:50 AM
EJ25 Height Width Length RockRaceScooby Subaru Conversions 2 09-22-2004 04:12 PM
Strange question - cleaning out frame rails ToJo Legacy Forum 4 05-01-2002 03:50 PM
what the HELL is a frame rail? Faraz Tri-State Area Forum 49 02-22-2002 11:10 AM
A frame rail ...Y isn't this covered? Faraz Warranty Issues & SOA Problems 8 02-22-2002 12:41 AM
