Old 01-22-2006, 07:45 PM   #1
eSToI Loco
Member#: 88579
2007 TurboLesbo FOX
Default Best way to torque wheel nuts?? car on/off ground, in gear, applying brakes??????????
Doing this solo, so cant have someone apply the brakes and the idea of prying the brake pedal does not sound too appealing.
I dont want to tighten nuts with the car on the ground having wheels supporting the entire weight of the car, and having the car off the ground and in gear while torquing does not sound right either due to potential damage to the tranny, so what is the best method?
eSToI Loco is offline   Reply With Quote
Old 01-22-2006, 07:51 PM   #2
shwaggin
Member#: 90017
2003 Forester 2.5X
WRC Wim-Wam Shaft
When I rotate my tires, I always just break the lug nuts free with the wheel jacked up a bit but the tire still touching the ground. I torque the lug nuts back on the same way.
shwaggin is offline   Reply With Quote
Old 01-22-2006, 07:56 PM   #3
eSToI Loco
Member#: 88579
2007 TurboLesbo FOX
thanks shwaggin, I guess this is the best method
Old 01-22-2006, 10:50 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
If you've got enough strength to damage your transmission while torquing the lugnuts then I hope to see you representing the US in the 2006 Met-Rx World Strongman Competition.
What shwaggin advised is the correct way to do it, as I imagine you would find in the gasp Owner's Manual.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-23-2006, 12:50 AM   #5
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
I have done my winter/summer swap multiple times and I have always done everything with the car jacked up, parking brake on and with the car in gear.
I would go back and retoque the wheel nuts after a couple days (or 50-100 miles later) but then I simply do everything without jacking up the car
Worked fine for me so far...
balajc is offline   Reply With Quote
Best way to soak carbon/oil build up off alloy? loccomoffo Built Motor Discussion 14 06-30-2009 07:11 AM
Best way to ship wheels from the US to Canada!?!?! kyotoegg Canada Region Forum 18 04-25-2007 06:41 PM
Correct way to torque lug nuts.... mikecoscia Tire & Wheel 10 05-22-2006 01:04 AM
best way to remove rear nut from front control arm? rex n effect Brakes, Steering & Suspension 5 04-28-2004 07:09 PM
Best way to transport wheels/tools to/from track cdraayer Motorsports 15 02-17-2004 01:08 PM
