Old 01-22-2006, 10:50 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default Piston slap?
Did all phase 1 engines have piston slap or is that just a usdm thing?
Lachlan is offline   Reply With Quote
Old 01-22-2006, 11:39 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
subaru motors tend to be prone to piston slap due to its design however the phase 1 EJ25 suffered heavily from it due to the large bore and stroke of the piston
Old 01-22-2006, 11:58 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
I was wondering because when I start up my ej20k if it's cold I hear some knocking noise from the engine, but it goes away when it gets warmer.
Old 01-23-2006, 01:11 AM   #4
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
yeah, thats cause the forged pistons expand more, so they have a larger tolerence when cold. common thing for forged pistons.
edit, 11:11.......
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-23-2006, 01:14 AM   #5
Lachlan
Member#: 19470
1981 Brat GL
good to know, thanks. I did read somewhere on this board that forged pistons expand less, but I guess you can't trust everything you read here...
Related but ot: Did the JDM EJ20's pistons have skirts or no?
Old 01-23-2006, 01:22 AM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
yessir
Old 01-23-2006, 04:46 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
forged pistons do expand less but they are still alumnium which means they are going to expand. Forged pistons usually are built with tighter clearances because of the fact that they won't swell like regular cast alumnium pistons. Sounds to me like you have normal piston slap, even my USDM wrx swap has a little bit on the very very cold mornings.
Old 01-23-2006, 11:27 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I have both forged and non-forged Ej20G pistons. I will see if I can find my pictures...
Old 01-23-2006, 11:29 AM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
Forged EJ20G piston...
Old 01-24-2006, 02:36 AM   #10
2slofouru
Member#: 90539
95 L with ej20k
powa, Raven R6
Default not a turbo ej but
My ej25 phase 1 does that too, in the morning. I worry about it being a bearing or excessive piston slap, I hope it doesn't develop into anything soon. It does go away by the time the engine warms up though.
2slofouru is offline   Reply With Quote
Old 01-24-2006, 11:10 AM   #11
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Originally Posted by HndaTch627
forged pistons do expand MORE but they are still alumnium which means they are going to expand. Forged pistons usually are built with MORE clearance because of the fact that they will expand more than regular cast alumnium pistons. Sounds to me like you have normal piston slap, even my USDM wrx swap has a little bit on the very very cold mornings.
Fixed that for you.
Factory EJ clearances: <.001"
CP/JE/Ross/Wiseco 2618 forged piston-bore clearance: ~.0035 to .0055" depending on application.
n2xlr8n is offline   Reply With Quote
Old 01-24-2006, 02:04 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Originally Posted by n2xlr8n
Fixed that for you.
ah crap...you are right, i said that backwards
Old 01-24-2006, 02:16 PM   #13
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I knew that you knew....that's why I didn't say "get your facts straight, you stinkin bastich"
S.
What Piston to use to replace piston slap brett-01 Normally Aspirated Powertrain 18 12-20-2011 06:19 PM
Piston slap after I changed pistons to Arias forged pistons tomoking Service & Maintenance 9 11-06-2003 08:48 AM
Piston Slap Question Kachukaa Normally Aspirated Powertrain 7 06-29-2001 01:08 PM
Piston Slap Quesiton Kachukaa Legacy Forum 3 06-29-2001 10:53 AM
MY '98 Piston slap problems Rovah Normally Aspirated Powertrain 5 11-27-2000 04:53 PM
Message Board Statistics All times are GMT -4. The time now is 10:03 PM.
