Old 01-23-2006, 03:55 PM   #1
go1d1e
RIP 2/21/14
Member#: 91263
02 WRX Wagon
Default Utec - MBC question.
Simple question, I cannot find the answer... Is the MBC required to run with the UTEC?
go1d1e is offline   Reply With Quote
Old 01-23-2006, 04:00 PM   #2
Gethin
Member#: 2998
It's not a MBC but a ABC. Read the UTEC user manual. The ABC is used to bleed pressure to the solenoid so you can reach the proper psi targets if your boost map does not get you there.
Gethin is offline   Reply With Quote
Old 01-23-2006, 04:09 PM   #3
go1d1e
RIP 2/21/14
Member#: 91263
02 WRX Wagon
Reading this - http://www.turboxs.com/faq/wrx.htm - it doesn`t say ABC/MBC.. but I think I got the answer to my question.. Basically, without the 'boost controller' you may not reach target boost levels. Correct?
Old 01-23-2006, 05:06 PM   #4
Gethin
Member#: 2998
It's in the UTEC user manual
http://www.turboxs.com/downloads/UTE...nual%205.0.doc
page 9 and 10
Old 01-23-2006, 05:12 PM   #5
REX8
Member#: 24038
Or you can use an MBC...
Old 01-23-2006, 08:02 PM   #6
go1d1e
RIP 2/21/14
Member#: 91263
02 WRX Wagon
Ok, page 10 on the link above..
NOTE: You must install and adjust the ABC on your WRX for the UTEC boost control to work properly. If you do not intend to use the UTEC to control boost the ABC is not necessary Each staged kit runs boost levels higher than are achievable with the standard factory boost control system. The ABC must be used to increase the flow capacity of this system in order for the UTEC to control boost properly. The following are the recommended boost levels for each staged kit.
RPM/Stage Stage 1 Stage 2 Stage 3 Stage 4 Stage 4 FMIC
4000 16.1psi 16.5psi 17psi 17.5psi 18psi
5500 15psi 15psi 15.5psi 17.5psi 18psi
6000 12.5psi 12.5psi 12.5psi 16.5psi 17.5psi
7000 12 psi 12psi 12.5psi 16.5psi 17psi
So, like i said.. it is not required unless you want the UTEC to control boost.. But obviously to increase performance, it would be good to have.
Old 01-24-2006, 09:46 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
lots of folks hit target boost WITHOUT the extra bleed.
others require it.
try it without, and take it from there.
FS: Utec, MBC, TXS Bov dropmech Engine/Power/Exhaust 14 08-10-2007 05:18 AM
utec+mbc+05wrx IronMedic Engine Management & Tuning 16 08-06-2005 06:50 PM
Utec+MBC+factory boost solenoid? CMJ Engine Management & Tuning 7 09-04-2004 11:27 PM
UTEC, MBC, and remote selector switch 1WikdWRX Private 'For Sale' Classifieds 8 08-25-2003 08:53 AM
Spoolup UTEC w/FBC/ABC vs UTEC/MBC? paulw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-13-2003 11:10 AM
