Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 01-23-2006, 04:08 PM   #1
raginbull74
Member#: 70708
2005 STI
PSM & back to stock!
Default low/rough idle on warm starts
ive just started having this issue. once i start the car after ive driven it, it idles really low....almost stumbles and dies, this last for about 10-15 seconds, then it climbs up to its normal +/- 500 rpm....it seems to be running rich, but im not sure. Im thinking it might be a MAF sensor prob, or a vacuum problem, but im not sure. I just recently added a mech boost gauge....but all the fittings seem to be tight. My other mods are a helix catless TBE and a Perrin drop in filter & light crank pulley. My EM is a GP moto stage 2 unichip....its been great for the past 4 months or so. Could it be the EM possibly? or has anyone had this problem before...if so have there been any threads related that could help?....Thanks
raginbull74 is offline   Reply With Quote
Old 01-23-2006, 05:37 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
Way too rich. I had a similar problem when my temp sensor (part of the MAF) was bonked and the car thought it was -20 C all the time.
Old 01-23-2006, 05:48 PM   #3
super-ru
Member#: 90094
2002 Pathfinder
Merlot Perl
I have this problem too, I think it's related to some temperature sensor. If it's below 32 degrees, I drive untill car is normal temp, park for 10-40 minutes, get back in and start it, I get a real bad idle. Mine has died 3 or 4 times at stop lights, or after I reverse out of my drive way and clutch in. Note, this ONLY happens when it's cold. I never had this issure in the summer. I think maybe the engine block and fluids are cooling asymetrically and the EM fuels improperly.
super-ru is offline   Reply With Quote
Old 01-23-2006, 05:49 PM   #4
raginbull74
Member#: 70708
2005 STI
acutally.....it started up after a week up in mammoth...it was usually pretty cool...what did you do? get a new MAF? or ? any suggestions as to what i do?
Old 01-23-2006, 05:53 PM   #5
super-ru
Member#: 90094
2002 Pathfinder
Merlot Perl
haha, i just keep the revs a little higher untill it warms up. It didn't bother me, and I figured its an obsucre artifact of my cars mods. I have Ultimate racing stage 4 + other parts.
Old 01-23-2006, 06:04 PM   #6
raginbull74
Member#: 70708
2005 STI
i do the same thing now....just give it a quick rev to 3-4k and it usually settles.....im just wondering if its gonna get worse
Old 01-23-2006, 06:07 PM   #7
super-ru
Member#: 90094
2002 Pathfinder
Merlot Perl
No, it doesn't happen to me on days above 40. Is it still happening when you are in warmer air? You might consider resetting the ECU after going to somewhere with a higher altitude and low temp.
Old 01-23-2006, 06:23 PM   #8
raginbull74
Member#: 70708
2005 STI
ah ok....ill do that...ill see whats up then
Rough idle on cold starts, AFR swings lean ogboot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-15-2009 07:08 PM
Rough idle when warm, 01 RS, yes I searched ;) rogue Normally Aspirated Powertrain 6 05-13-2009 05:39 PM
rough idle on cold start ups hockeygm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-02-2009 10:38 PM
Bad idle and killing on warm start? Subiemax Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 03-20-2006 11:09 PM
Low/rough idle? sybir Legacy Forum 16 10-11-2003 10:11 PM
