Old 01-23-2006, 08:40 PM   #1
VajraTLR
Member#: 13156
2004 WRX
JBP
Default what is the correct offset for an 18x8 wheel on an 04 WRX???
is it +44?
Thanks,
VajraTLR is offline   Reply With Quote
Old 01-23-2006, 10:52 PM   #2
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
NO
It depends on what kind of tire you want to run and if you drive a wagon or sedan.
There is a very nice sticky thread at the top of this forum.
dbrier is offline   Reply With Quote
Old 01-24-2006, 10:22 AM   #3
ripvw
Member#: 27790
which is sadly filled with misinformation
the correct offset for any subie wheel will always be the one closest to stock, at least as far as steering response and wheel bearing life are concerned. Stock wheels for the Impreza run ET55 or ET53. For example, there is a Subaru factory 18x8.5 wheel made by BBS which is ET53.
in the aftermarket, there are several ET51 18x8's - OZ Superleggera in gold (closeout @ TireRack), Prodrive PFF7, and SSR GT2. Lots more choices at ET48. ET44 would be on the low side, and would likely lead to rubbing on the rear fender if used with a 225/40x18 tire on a wagon. depending upon the tire and lowering springs, it might even be an issue with lowered sedans. unless you just have to own that particular wheel, I'd recommend getting an 18x8 with a higher offset...
http://www.miata.net/garage/offset.htm
ripvw is offline   Reply With Quote
Old 01-24-2006, 02:43 PM   #4
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Someone who knows what he is talking about.
<-- sports STi, LGT and WRX wheels on his car - all with offsets between 53 and 55
Old 01-24-2006, 03:55 PM   #5
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
+44 is on the low side for offsets. For an 18x8 wheel I would recommend sticking from +48-+53 as others have mentioned. The offsets in this range will be friendly to your wheel bearings and also allow you to run a fairly wide tire without rubbing.
-Dan
suby_dude is offline   Reply With Quote
What is the correct part# for the 20 22 24 adj whitline RSB? breathinez Brakes, Steering & Suspension 4 11-09-2006 01:55 PM
what is the correct backspacing for 18's on 05sedan bigworm Tire & Wheel 1 06-14-2005 11:31 PM
What is the right offset for the 04 2.5RSs ImpreziveRS415 Tire & Wheel 1 05-12-2004 01:57 AM
What is the correct offset? 1quikrex Brakes, Steering & Suspension 31 04-11-2002 01:10 PM
What is the ideal offset for 18x7.5 wheels? scootr Brakes, Steering & Suspension 9 04-27-2001 06:26 PM
