Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 01-23-2006, 08:30 PM   #1
polak13
Member#: 105816
01 Impreza 2.5 rs
Default 2.5RS no spark...fuel pump relay clicking
Hi all,
One morning when I went to start my car I would not fire. It cranks, I put a new relay in and I checked the fuel press...Ok pump works, I did not get spark however. I checked resistance on coils looks fine. So I tried to link up to my ecu with the hand held diagnostics tool....no link! Did any one have this problem before? I had the same symptoms, relay clicking car cranks, 7 months ago and relay fixed it (or I thought so). Is it my ecu? HELP!
polak13 is offline   Reply With Quote
Old 01-23-2006, 08:38 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Which relay?
The starter solenoid?
Old 01-23-2006, 09:48 PM   #3
polak13
Member#: 105816
01 Impreza 2.5 rs
No it is the relay that controls the fuel pump. It's located under the dash driver side on the side, next to the main relay. There is a bracket there with three relays...fuel pump, main, and rear accessory power suply relay.
Old 01-24-2006, 12:19 PM   #4
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Check the fuse box under your hood. Sounds like your having a problem identical to mine. SBF #2 or #5 is probably blown out. After extensive research into my issue, I learned that SBF #2 connects to the fuel pump relay, main relay, ecm, AND ignition relay on my car. On other cars it's SBF #5. My car has been out for 3 weeks because of it...
bongchild is offline   Reply With Quote
Old 01-24-2006, 04:32 PM   #5
polak13
Member#: 105816
01 Impreza 2.5 rs
I'll check that out...I did a quick visual insp. on my fuses when relay did not work. Also I ordered a used ecu $60 will be here on thur.
Old 01-24-2006, 04:46 PM   #6
russd32
Member#: 63961
It's probably a bad relay. If you unplug that relay so that the fuel pump doesn't run you won't get any spark either. I just figured that out last weekend when checking my coil.
russd32 is offline   Reply With Quote
Old 01-24-2006, 05:15 PM   #7
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Be sure you are under sufficient light (preferrably sunlight) and look very closely. You may notice that one of the fuses i mentioned has a matte finish while the other is shiny. Electrical problems are a biatch to troubleshoot/pinpoint.
Old 01-24-2006, 08:34 PM   #8
polak13
Member#: 105816
01 Impreza 2.5 rs
I replaced it (fuel pump relay) and new one was going on and off just like the old one...are you talking about a different one? I cranked the car with the new relay in and got no spark. Are you saying to crank it with the relay out of car?
Old 01-26-2006, 03:25 PM   #9
polak13
Member#: 105816
01 Impreza 2.5 rs
Just to let you all know it was a computer issue. I just got one from a junk yard today for $60 and RS started right up.
need fuel pump and fuel pump relay 4/18/10 raceckr MWSOC Private Classifieds 1 04-18-2010 03:05 AM
cranks, no start where the f is my fuel pump relay EntertheWagon Newbies & FAQs 26 07-10-2009 01:48 PM
Fuel Pump Relay Control and Airconditioner Cut Relay Control modifiedauto Newbies & FAQs 0 09-19-2007 08:43 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
EJ22 Swap - No Spark... no ground for fuel pump relay?? Subarutex Subaru Conversions 5 01-22-2007 12:14 PM
