Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-23-2006, 09:11 PM   #1
BLK REX
Member#: 102673
2000 Legacy GT LTD
Default hYdra: Stage injectors?
Would the hYdra allow one to use an 8 injector, stages setup? Im talking at lower load 4 injectors are firing, and at higher load an additional 4 kick in.
Thanks..
BLK REX is offline   Reply With Quote
Old 01-23-2006, 09:22 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Yes it does
Straight from the Hydra Site:
Injectors:
The Nemesis 2.1 is capable of running cars upto 8 Cylinders sequentially. Injection modes are sequential, batch fire and throttle body injection. When not used for injection, outputs 2 - 8 can be used for staged injection or general purpose switching, and outputs 2 - 5 can be used for PWM control .
Old 01-23-2006, 09:23 PM   #3
BLK REX
Member#: 102673
2000 Legacy GT LTD
Thanks sir.
And, one last question. Is the hYdra MAF, MAP, or TPS based?
Old 01-24-2006, 10:01 AM   #4
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Originally Posted by BLK REX
Thanks sir.
MAP based (it has an onboard MAP sensor). It can run in "TPS" mode (which estimates load based on TPS position, but it is not recommended for normal use and is STRONGLY discouraged on turbo cars, since boost is not as TPS dependent as the loads on an N/A car are.
Shane
Warp3 is offline   Reply With Quote
Old 01-24-2006, 04:43 PM   #5
BLK REX
Member#: 102673
2000 Legacy GT LTD
Thanks sirs. Nice to see people on forums actually answering questions..
Old 01-25-2006, 02:13 PM   #6
bboy
Member#: 56468
04 Improved STI
Dirty White
I think you'd have to get a custom Hydra to do it, but like folks have said the Hydra can control 8 injectors--each with individual resistances and trims.
Agreed, MAP based.
I encourage you to talk with Phil about your set up.
Old 01-25-2006, 03:26 PM   #7
Master2192
Member#: 83254
98 2.5 RS
04 WRX
+1 on talk to Phil
I'd also see when the Hydra 2.5 is coming out because it offers faster start up and more features.
Old 01-25-2006, 04:14 PM   #8
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Thanks..
Yes, you can do this but it does require some additional wires added to the harness. In all honesty there really isn't much of a benefit for most since the Hydra can control low impedance injectors. We have tested up to 1000cc and up to 680 whp without any downsides. If you plan on higher HP than this you can try 1600cc injectors but I have not tested these to ensure they will idle cleanly at 14.5-14.7 AFR (I suspect they will be close). This would be my first choice as itís 2 less fuel rails, 4 less injectors, 4 less potentially leaky fuel seals, 4 less electrical connectors to wire, and 4 less potential air leaks, and less wires to the Hydra.
Now if you insisted on running 8 injectors you can. The second set are run in batch mode and only activated when the standard 4 injectors are run at maximum.
Thanks,
Phil
http://www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 01-25-2006, 07:54 PM   #9
stu
Member#: 25768
35R bugeye
Slowbaru
Originally Posted by Master2192
+1 on talk to Phil
any news about the release date Phil
Later Jeff
stu is offline   Reply With Quote
Old 01-26-2006, 09:35 AM   #10
Element Tuning
Member#: 54918
673 WHP Element
The Element Hydra 2.5 units just started shippping but due to a large back order we're still filling, I haven't promoted them.
Thanks,
Phil
Element Hydra: '05STi ALS/DCCD ?'s Soon2Bgreat Other Engine Management 2 10-15-2005 10:53 AM
Installed the Ultimate Racing GT35r kit with Hydra: feels absolutely amazing syoung0298 Off-Topic 47 07-31-2005 12:07 PM
Installed the Ultimate Racing GT35r kit with Hydra: feels absolutely amazing syoung0298 Off-Topic 27 07-29-2005 10:25 AM
hydra: 2 step. NeaD Other Engine Management 0 06-10-2005 12:40 AM
Power Enterprise 650cc Dual-stage Injectors in stock Gruppe-S Vendor 'For Sale' Classifieds 14 08-25-2003 10:05 PM
