Old 01-23-2006, 09:53 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Immobilizer input needed.
I'm working on gutting the legacy for my swap and want input on the immobilizer. Do I need the actual ignition? or just all the wiring around it?
How do I remove the ignition from the steering column?
Joshua
yebokmj is offline   Reply With Quote
Old 01-23-2006, 10:27 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i have given some thought to this
do you have the key that is married to the ecu
i suspect that you could super glue the imobilizer key to the rfid reciever and use what ever ignition
Old 01-23-2006, 11:05 PM   #3
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
That wont work, or shouldn't work in theory. The system was designed to have the key in the ignition in order for the immobilizer to work.
You have to break the bracket to remove the ignition dealie.
THAWA is offline   Reply With Quote
Old 01-23-2006, 11:26 PM   #4
yebokmj
Member#: 2213
Brilliant Red
Okay if I have to break the bracket then how do I put it in the next car? I have yet to tear apart my car to see how the one it would be replacing is held on. I'm wondering if my bolt out kit might work and then I can just replace them with conventional bolts. I'll have to give it a shot.
Joshua
Old 01-24-2006, 12:53 AM   #5
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
Could you just swap the steering column?
I'm assuming you are using the 05 crossmember and rack?
EDIT: I just read the other thread about the issues with the crossmember and rack. If the crossmember and rack are a no go, my idea is kinda busted. I just brought it up b/c I wanted to go STi rack and had to consider getting the STi column to save the u-joint fab you could always use the column and fab the u-joint to use the older style rack.
UTCiv is offline   Reply With Quote
Old 01-24-2006, 01:55 AM   #6
THAWA
Member#: 44581
3 Boxers 2 AWD
You remove the bolts if you want to use the ignition switch in the next car. If you break the bracket where it surrounds the bolts you can do it this way. Or I suppose you can try to cut the heads off the bolts and use a stud remover to get them out. All new gen subarus are setup this way to help prevent theft. You tighten the bolts down until the head snaps so you can't remove the ignition switch and free the steering lock.
He could just use an 05+ crossmember to use the LGT rack.
I need to know if I should buy a Borla Header for my WRX--Input needed bruce cohen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-08-2003 01:24 AM
Your input needed FS 2000 RS coupe? SubyPrez20 General Forum Archive 0 12-20-2000 08:24 AM
close to purchasing MY01, input needed... shukes24 General Forum Archive 11 09-11-2000 12:30 AM
Attn Rallycross participants, your input needed... Subie Gal North West Impreza Club Forum -- NWIC 7 08-11-2000 06:53 PM
NE Ohio Meet....Input Needed rpone605 General Forum Archive 146 08-05-2000 09:33 PM
