Old 01-24-2006, 10:35 AM   #1
haji
Member#: 54624
1999 impreza wgn
Default Shim over bucket to Shimless swap?
Does anyone know if there is a way to change shim on bucket to shimless?
Are they the same diameter at all?
Anyway to increase RPM range of shim on bucket?
I need more revs!
But I don't need my heads flippin coins.
haji is offline   Reply With Quote
Old 01-24-2006, 12:26 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What heads are you running?
Old 01-27-2006, 01:29 AM   #3
haji
Member#: 54624
1999 impreza wgn
98 legacy GTs N/A cams. They have shim on buckets, and I'm scared to over-rev.
Old 01-27-2006, 04:45 AM   #4
Skully
Member#: 48990
98 Impreza RS
RBP
i took my heads to 8k RPM without a problem. I have a 98 RS.
-Thomas
Skully is offline   Reply With Quote
Old 01-29-2006, 08:09 PM   #5
haji
Member#: 54624
1999 impreza wgn
Like.. once, or a lot?
Old 01-29-2006, 08:35 PM   #6
Stealth_RS
Member#: 95677
2004 WRX
how the hell can you go over the 6.5 stock rev limiter?? on the 98 RS
Stealth_RS is offline   Reply With Quote
Old 01-30-2006, 07:45 AM   #7
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
easy, theres this thing called standalone ecu.....
to answer the original question, you can change to under bucket shim or shimless. stop by your subaru parts deparmetn (or go online to subaruparts.com) and pull up the diagrams for the 2002 wrx and a 2005 wrx head parts. the newest ej205 is shimless, the valves and keepers and such should be the same, so if you look at two diagrams.....
swapstar is offline   Reply With Quote
Old 01-30-2006, 08:57 AM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
If this works out to be right...this thread should get stickied up top.
Jay Storm
Old 01-30-2006, 03:00 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
-Thomas
I got those heads in my garage. Are you sure they didn't have any problems?
But there are a number of guys who have taken DOHC EJ25 heads to 7500rpms with 20+psi of boost without issues. The Ej25 heads are very similar to '97-98 EJ20 heads and the shimless conversion for them will work on your heads if you insist. MRT sells the kit off their website. I haven't looked in a while, but it is expensive...
Old 02-01-2006, 11:30 PM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
There are about 30 or so part numbers for the shimless buckets. You might want to measure some stuff before you purchase.
Tim Sanderson is offline   Reply With Quote
Old 02-02-2006, 01:08 AM   #11
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
NAh, Just buy 16 of each different part number. You should be good to go.
THAWA is offline   Reply With Quote
Shimless Bucket vs Shim Over Bucket soobaviator Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-24-2010 01:58 PM
Ej20k w/shim over bucket?? Cbgrandtheftauto Pre-2002 Factory Turbo Powertrain 8 03-10-2010 04:41 PM
Shim over bucket vs. Shimless bucket question. sick1.8t Built Motor Discussion 11 09-04-2007 11:49 AM
Tech Works Shim Under Bucket Question-Where to get replacement shims? MY99 2.5GT Built Motor Discussion 14 04-19-2006 02:33 PM
shimless or shim under buckets for wrx heads TexRex2002 Private 'Wanted' Classifieds 0 05-07-2005 11:17 PM
