Old 01-25-2006, 03:16 AM   #1
Subiemax
Member#: 30691
2013 FRS
RED
Default methanol
Just bought a meth injection kit.
Any one know a good place to get methanol?
Online or a type of store that would stock it?
Subiemax is offline   Reply With Quote
Old 01-25-2006, 06:30 AM   #2
Silverpike
Member#: 92399
powermist (dot) com
[grr, sucks being a new poster... ]
Silverpike is offline   Reply With Quote
Old 01-25-2006, 06:34 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
You can buy methanol at any major hardware store in gallon quantities, about $10.00 /gal.
If you buy fuel methanol from a racing fuel supplier you will pay about $2.25/gal.
There are several racing classes that use methanol fuel, dig out your phone book yellow pages and look for speed shops that cater to the circle track or drag race folks and you will probably find a source of fuel methanol.
Larry
hotrod is offline   Reply With Quote
Old 01-25-2006, 06:59 AM   #4
TheMadScientist
Member#: 23717
2005 Big red
Larry
I know in MA most hardware stores don't carry meth. But the paint stores do.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-25-2006, 07:19 AM   #5
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
me and a couple of my friends bought a 55 gallon drum for around 175.00 the key thing there was telling the distrubuter that we were using it make our own washer fluid if you tell them your using it for fuel then all sorts of taxes bump the price up a hell of alot, we did this back in the spring and still have about 15 to 20 gallons or so left roughly.
mike
tribalwrx is offline   Reply With Quote
Old 01-25-2006, 06:04 PM   #6
Silverpike
Member#: 92399
Larry
BTW, I just thought I should add one more thing.
Methanol is highly corrosive, and carcinogenic. It needs to be handled and stored with great care. Make sure you have a safe place to store it, and it would be wise to take safety precautions before pouring it.
Old 01-25-2006, 06:34 PM   #7
Absubtle
Member#: 85862
And it likes to absorb water (hygroscopic... I thought it was hydroscopic... but there is no such word. hygroscopic means
1 : readily taking up and retaining moisture
2 : taken up and retained under some conditions of humidity and temperature)
But methanol should be stored up off the ground, say a pallet, and needs to be stored in a solid color, not clear. It needs to stay away from the sun at all times, and it does like to suck in the water.
At my previous shop, we had to dump quite-a-few gallons because they were tainted w/ water.
Methanol is very, very corrosive. It ate thru anodized AN fittings in no time. It needs constant maintenance to keep the corrosion down.
When we ran it in our drag Honda, 8 x 1800cc injectors, the menthanol ate thru all the anodized fuel rails and AN fittings.
According to other experts in racing.... ethanol is less corrosive and has a less consumption for proper air/fuel mixture than methanol (using lambda values only, you really cannot tune w/ a stadard wide band. I think we were at 6.2 to 1 air/fuel ratio on an Autronic Wideband which meant a 11.5 air/fuel ratio in lambda values.
We could buy a drum for around $80, $1.60 a gallon, better than paying $6 a gallon for C16 and only making 70 percent of the power.
Anyway, it's fun stuff
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 01-25-2006, 10:42 PM   #8
Absubtle
Member#: 85862
We bought our barrels of C16 and menthanol thru Sunoco.. But who knows what the real deal is right now. Just 3 months ago, it was different.
Absubtle
PA
Old 01-26-2006, 12:10 AM   #9
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Get it here:
meth on-line
DP
Here is another place. From the turbobuick guys.
http://www.turbobuick.com/forums/sho...d.php?t=121500
DonkeyPunch is offline   Reply With Quote
Old 01-26-2006, 01:37 AM   #10
zaxrex
Member#: 9898
Water Injected Blue
I get mine local from World Wide Racing Fuels
Like the others have said, storing this stuff requires attention.
I left in contact with aluminum in large quantities, it will start corroding the aluminum, and the byproduct is hydrogen gas.
Boom
zaxrex is offline   Reply With Quote
Old 01-26-2006, 08:50 AM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Methanol is highly corrosive, and carcinogenic. .
corrosive, yes.
carcinogenic, no.
it's not benzene.
Old 01-26-2006, 11:03 AM   #12
edmundu
Member#: 54672
Isn't common winter washerfluid about 40% methanol, and the rest water with some soap? These things are stored in clear plastic bottles, and sit on shelves in practically every store, from supermarkets to auto parts stores...
question: So can't we cut the methonal with water 50/50, and then store it safely? In say those solvent type cans, which help to keep moisture out, and from allowing the meth to evaporate?
edmundu is offline   Reply With Quote
Old 01-26-2006, 11:48 AM   #13
Davenow
Member#: 23676
Larry
3 different states, not one of them has Methanol in ANY hardware store.
MA
PA
TX
No meth in the HW stores.
Fuel oil supply places carry it sometimes though.
Old 01-27-2006, 04:32 PM   #14
zaxrex
Member#: 9898
Water Injected Blue
Yep.
But also look at what else is put out in the open, drain cleaners, bleach, ATF & brake fluid. Shoot, yah can get cans of toluene & paint thinners that are more hazardous to your health. Just look at the warning and handle everything appropriately.
Old 01-27-2006, 10:42 PM   #15
TheMadScientist
Member#: 23717
2005 Big red
Dihydrogen Monoxide
http://www.dhmo.org/msdsdhmo.html
Careful it is deadly
TMS
Old 01-27-2006, 10:59 PM   #16
Silverpike
Member#: 92399
Originally Posted by ride5000
corrosive, yes.
carcinogenic, no.
it's not benzene.
Whoops, I thought I remembered reading that.
For a very exhaustive review of pump gas and other gasoline additives, check out the gasoline FAQ:
http://www.faqs.org/faqs/autos/gasol.../preamble.html
Part 4 specifically addresses common fuel additives like ethanol, methanol, propylene oxide, and nitromethane.
93 oct, E85, +Methanol injection, Race fuel, Straight methanol -What's the hierarchy? SharpByCoop Proven Power Bragging 74 04-10-2010 11:32 AM
where can I get methanol & toluene azncandyman General Community 14 05-22-2004 01:18 PM
Any place to buy methanol around Boston? scrat New England Impreza Club Forum -- NESIC 5 03-23-2004 01:26 AM
New Methanol Fix for MA residents chrislehr New England Impreza Club Forum -- NESIC 11 10-03-2003 07:51 PM
10% Methanol addition ? Cosie Convert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-20-2002 07:21 PM
