Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Vancouver Impreza Club
Old 01-25-2006, 05:32 AM   #1
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Default Injector Question... need the experts!
I'm looking for a set of injectors for my 00 RS that are 'Plug-n-Play' in every way into my car that flow at a higher rate. Aftermarket or OEM. Which ones are a DIRECT fit?
The more common answer I've gotten is others "... think STi pinks fit... ". I found a few aftermarket injectors for this engine, but with flow rates well beyond my purposes.
Now if there's possibility that STi pinks are a direct fit into a USDM GC8, and those with older WRX's upgrade to pinks, then in theory, I would imagine WRX blues are also a fit?
I'm ready to buy, I just don't wanna get a set that I can't use. I was also told there are a few variations of the EJ25... how do I know which one I have exactly?
clsmooth is offline   Reply With Quote
Old 01-25-2006, 02:52 PM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Nothing without using adaptors - The 00 manifold has air assist so it needs some work to get other top-feed injectors to seal properly. Best solution is to swap for a 99 manifold and then you can choose between the stock WRX injectors or the STi pinks. How much boost you intend to run? If you're not going too far beyond what you're running now, a set of used WRX injectors with either a bunch of O-rings or adaptors from RalliTEK should work.
kgb is offline   Reply With Quote
Old 01-25-2006, 04:31 PM   #3
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
That sounds like a good setup for me... now, who's RalliTEK?
Old 01-25-2006, 07:52 PM   #4
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
http://www.rallitek.com/
O-ring kit - they used to have a better adaptor kit but I couldn't find it.
You can probably source the o-rings locally
Old 01-26-2006, 01:14 AM   #5
tony_subaru
Member#: 22742
RC injectors had ones that fit. People complained about fitment issue, but I know two people with them with no fitment issue.
tony_subaru is offline   Reply With Quote
Old 01-26-2006, 01:45 AM   #6
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Don't know if you can still get them new from RC - AFAIK, they were more like trial product that worked well for some.
Old 01-26-2006, 05:54 AM   #7
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
Awesome! Thanks for the website, I've emailed them.
I'll check on RC too, never know...
Old 01-26-2006, 02:41 PM   #8
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Keep me posted - eventually I would need injectors for safety
Old 02-04-2006, 07:20 PM   #9
clsmooth
Member#: 86394
2000 RS Coupe
2005 Forester X SE
I picked up some STi pinks off eBay for pretty cheap, we'll see how that goes.
Launch control questions for the experts... Brian Broz Engine Management & Tuning 2 07-06-2003 03:54 PM
tire question for the experts JVG Brakes, Steering & Suspension 4 08-15-2002 03:54 PM
Question for the experts, Momo wheels judgegavel Brakes, Steering & Suspension 5 07-04-2002 03:44 PM
Boost Question for the Experts TurboRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-07-2001 12:56 AM
Mismatched tire question for the experts Xio Brakes, Steering & Suspension 4 08-15-2001 08:00 PM
