#1 |
Member#: 92399
Vehicle:02 Bugeye WRB |
Hey guys, I have had some links for DIY alcohol/water injection systems for some time. Thought I should share with everyone looking to go a different route than the commercial SMC, Aquamist, or Snow kits.
Propane Injection: http://www.importpoweronline.com/propanecontent.html Lots of DIY links: http://members.cox.net/stevemonroe/AlcoholInjMod.html Exotic Fuel Information: http://www.turbofast.com.au/racefuel.html RSR Water Injection stuff (includes nozzle calculator) http://www.rbracing-rsr.com/waterinjection.html |
#2 |
Member#: 54604
Vehicle:2004 FXT Cayenne Red (sold) |
Riftswrx - a tuner here, with a parts and price list, mostly up to date. Suby specific.
http://www.projectwrx.com/modules.ph...howpage&pid=34 |
#3 |
nozzles:
http://www.mistcooling.com/nozzle_cost.htm diy install on talon: http://lokmeup.iwolfe.com/Talon/WaterInjection.htm |
#4 |
Member#: 104155
what advantages would that provide?
#5 | |
Member#: 16200
Vehicle:tic- toc the countdown has started |
...run a 100 octane map on 93 for as long as the tank is full ![]() |
#6 |
Member#: 88467
NESIC
Vehicle:2005 BLK ON BLK GD |
Silverpike - thanks for the great info!
been considering the aquamist but i'm a DIY kind of guy. Uncle Scotty - exactly ![]() |
#7 |
Member#: 9898
Vehicle:2002 WRX Water Injected Blue |
Aquamist nozzels are hard to beat for dropplet size distribution uniformity, as long as you keep the pressure up. You can also tear them down and clean them if you happen to use windshield washer fluid in an emergency and need to clean the gunk out afterwards.
#8 |
re: uniformity.
i have read that uniformity is not always the ultimate goal, since optimally some finer droplets will immediately vaporize, pulling out heat, and other, larger droplets will find their way into the combustion chamber, where they buffer the combustion process itself. just relaying what i've heard. |
#9 |
Member#: 69072
Alky is the way to go with turbo cars, they love beng alcoholics, if you know what you are looking for a DIY kit it works out quite nicely
#10 |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 07 Blk/Blk Mazda 6 |
Subscribes.
#11 | |
Member#: 88467
NESIC
thats the exact reason i'm considering this kit. you sound like you have a lot of experience with it. do you run the aquamist setup? what are your impressions of it so far if so? |
#12 | |
Member#: 92399
DIY I think is especially suited for people with custom mods. Most of the kits are pretty well put together, but each of them seems to have some weaknesses. Perfectionists can do better if they want to do it all themselves. More exotic setups operate similar to a direct-port nitrous install, using one nozzle per runner. One more thing about Propane injection. Propane tends to be less useful for gasoline motors, because the octane increase can be done using ethanol or methanol. Propane tends to be well suited to diesel. The complication with propane is that it is gaseous at normal temperatures, which makes flammability a major problem. Half-assing a propane installation is a great way to get killed. ![]() |
#13 | |
the issue i have with such setups is that the put the same amount of ADI in each cylinder. the debate is still raging whether or not the intake and exhaust manifolds flow evenly enough across all cylinders. putting one larger injector at a central location will insure that if more charge air goes to one cylinder, so too will more ADI. that is a "good thing" in my book since it will make sure you don't over ADI and snuff out the other cylinders which are pulling less air. just some theorizing. |
#14 |
Member#: 88322
Vehicle:2004 WRX STi JBP |
I'm not positive that unequal airflow means liquid particles will also flow equally unequal. Err... You know what I mean.
#15 | |
![]() and i agree. particularly when the manifold was never designed as a "wet" manifold. i just wonder what the benefits of per port injection (thus guaranteed equal distribution) would be. i also wonder if it would make a blocked nozzle harder to detect. |
#16 | |
Member#: 9898
Their stuff is very robust and reliable. Ran the pump dry a few times and it still survives, small nozzels are easy to mount. Service & support from the manufactureer can teach a lot to outher outfits. |
#17 | |
Member#: 9898
The vids do a good job showing that the momentum of the water carries it to the outside of a turn. With the way the intake manifold is set up, I put my single injector on the bottom of the hose before the TB. I wanted to get more water into #3 which branch off below that #1 runners. I hope that in this case, I am taking advantage of dissimilar distribution (I do not know if #3 are hotter than the front ones, but I think they are). The direct runner or port injection points take that variable out, but you have to make sure that the water flow is equal at all injection points. I am looking forward to seeing if there is any splat pattern on the inside of the manifold after using WI for a couple of years, especislly since methanol reacts with aluminum. I figure if I have to take the manifold off to get rid of the cold weather gas smell, might as well take a look. |
#18 | ||
Member#: 92399
![]() Quote:
#19 | |
Member#: 15350
Vehicle:2002 WRX Sedan Midnight Black |
With say a UTEC, or reflash, I don't think it would matter much at all. -jason |
#20 | |
#21 |
Member#: 81659
NWIC
Vehicle:200X Impreza Proper Fitment Crew |
I will be taking pictures of my system here in a few days, it uses the aquamist jets, but shruflo pump, accumulator, pressure switches from cooling mist and solinoids from them. I have it doing a dual stage setup. Rated at 100psi.
