Old 01-25-2006, 08:53 AM   #1
chris84bond
Member#: 51723
Default Retarded Throttle Position Sensor Question
My engine is racing when it is first started and for the first...5 mins or so of driving. Had it checked out, friend said it was the TPS that needed adjustement. Is there a way to DIY that is easy, or would it be easiest to take it to someone, and who would that be. Subaru probably?
Or....
Should I just buy a new one...would that correct the problem?
Thanks
-Chris
93 Impreza L
chris84bond is offline   Reply With Quote
Old 01-25-2006, 03:30 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
You should be able to do it yourself. But I'm more inclined to say its your IACV instead of the TPS. If it was the TPS you should notice the affects at all times, not just when its cold.
Old 01-25-2006, 08:14 PM   #3
chris84bond
Member#: 51723
IACV=?
Idle air control valve...gotcha
It's more when it's cold than not....higher rpm(idle at 1.5k instead of 1 and under) and it slips a little. I know about 3 months ago, the IACV was completely carboned over..car wouldn't even start. Carb cleaner==temp fix. Was hoping I wouldn't have to shell out the money for a new one...
Damn
Old 01-25-2006, 09:43 PM   #4
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
If the IACV is gunked up already you may want to take a peak at your intercooler. Oily? Blow by on the rings or valve seals could be your culprit. A catch can will mask the issue somewhat until you can find the real issue.
phantomsr is offline   Reply With Quote
Old 01-26-2006, 12:12 AM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Idle at 1.5k isn't that uncomon in cold weather...heh...but you are talking Florida cold and I'm talking "its warm when its 25* out".
IACV. Buy another gasket, take yours off and clean it.
cdvma is offline   Reply With Quote
Old 01-26-2006, 12:37 PM   #6
chris84bond
Member#: 51723
No intercooler...It's only a 1.8L stock right now...
Old 01-26-2006, 12:39 PM   #7
chris84bond
Member#: 51723
The idle only stays that high for about 5 mins of driving, then drops. Sometimes, the tranny goese slip slip tho, and the tranny is good from what everyone's been saying. Could that be the IACV as well doing that?
Thanks
-Chris
Old 01-26-2006, 12:56 PM   #8
jmussetter
Member#: 15350
2002 WRX Sedan
Midnight Black
Everything that you're describing sounds normal for a car when it is first started.
The IACV lets more air into the Throttle body when the engine is cold so that it will stay running while it warms up. As the coolant in the engine warms up, it is circulated to the T.B. and the IACV reacts to this by closing it's valve so that the extra air doesn't come in anymore. And Whala! The car is back to it's normal idle RPM after this. I live in California and exp. the same thing that you're describing, even in this climate.
The clutch is also cold, and like brakes, need to warm up before they get "sticky" enough to grab and hold power the best. The tranny heat's up 1 of 2 ways, 1-by friction inside, and 2-radiated heat from the engine. While the engine warms up, so does the tranny, and clutch that is connected between.
-jason
jmussetter is offline   Reply With Quote
Old 01-26-2006, 04:45 PM   #9
chris84bond
Member#: 51723
-jason
I would agree and say that this is normal, but it didn't do this before...or in the past 3 years I've owned the car in the cold...
throttle position sensor question Prodian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-29-2007 10:45 PM
Throttle Position Sensor Question sekretskwirl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-07-2007 05:19 PM
wtb: Tumble Generator Valve (TGV) sensor / Throttle Position Sensor (TPS) Sensor simprezl25 Private 'Wanted' Classifieds 0 01-10-2007 04:25 PM
FS: 2.5L throttle body + throttle position sensor + air/idle speed controller. SjYankee006 Private 'For Sale' Classifieds 3 02-15-2005 12:26 PM
EJ20G question - throttle position sensor compatability Fitz Subaru Conversions 2 05-25-2004 08:52 AM
