Old 01-25-2006, 09:25 AM   #1
ShawnRS
Member#: 18797
MY06 WRX Wagon
Default noob question: Tuning for better gas Milage
Hello,
I just bought a MY06 Wagon this last boxing day. I love the power but I am wondering if anyone has done a reflash with No Mods just to achieve better gas consumption while maintaining current power levels?
I know I can just lift the right foot etc....
Shawn
ShawnRS is offline   Reply With Quote
Old 01-25-2006, 12:26 PM   #2
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
You can't really do it while maintaining stock power levels. If you are willing to give up some power, you can set your boost targets to wastegate pressures, adjust fueling accordingly (e.g., add a little less) and add some timing. I'd done this, and went from 155whp on a stock car (195whp tuned @ stage 2) to more like 125whp (nice flat torque curve though!). Car was still driveable, just not very fun. Used it a few times for driving to Thunderhill or Monterey (both 3 hour drives).
mcowger is offline   Reply With Quote
Old 01-25-2006, 12:37 PM   #3
WingNut
Member#: 14951
GDA
free up the exhaust restrictions w/aftermarket pipes and then do a retune.
WingNut is offline   Reply With Quote
Old 01-25-2006, 12:59 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
That won't really effect "cruise" milage. It will only effect hard throttle milage.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-25-2006, 01:06 PM   #5
Trainable
Member#: 101816
06 WRX TR
SGM
Another question you might want to think about is if reflashing with an economy map will void your warranty on engine and/or tranny. Anyone know the answer to this one?
Trainable is offline   Reply With Quote
Old 01-25-2006, 01:11 PM   #6
ShawnRS
Member#: 18797
MY06 WRX Wagon
Does Subaru still tune their car pig rich? If the car is leaned out, safely, will that save fuel.
It's not a huge concern I'm just thinking.
Shawn
Old 01-25-2006, 01:11 PM   #7
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
Get a AP and run the economy map or just keep you boost off = accelerate really slowly.
I gave up on this after a while
Sausage is offline   Reply With Quote
Old 01-25-2006, 01:16 PM   #8
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
TMS
The boost changes won't affect cruise at all, correct....I never suggested it would. But it would help during the non cruise times. The timing advance changes *would* help throughout the range.
Old 01-25-2006, 01:18 PM   #9
hondaeater69
Member#: 60324
i believe ECUtek flashes now have the ability to tune for leaner conditions than 14.7:1 in closed loop/cruise situations, may want to look into that.
hondaeater69 is online now   Reply With Quote
Old 01-25-2006, 01:57 PM   #10
bboy
Member#: 56468
04 Improved STI
Dirty White
Poor cruising mileage is due to the low compression ratio of the turbocharged engine.
On boost the car can certainly be tuned leaner and with water injection even leaner. You are current wasting >20% of your fuel as a coolant for the cylinders.
Let's say you install water injection and lean out your fuel by an average of 25%. That's only 25 mpg on what was 20 mpg. It's alot of work for a little improvement. The compression ratio (that allows you to run all that boost) is the real fuel efficiency killer.
Old 01-25-2006, 01:59 PM   #11
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You do not want to use water injection for crusing situations. Its rediculous how quickly you could go through a gallon of water.
cdvma is offline   Reply With Quote
Old 01-25-2006, 02:07 PM   #12
bboy
Member#: 56468
04 Improved STI
Dirty White
The key word there is 'average'.
I didn't say use WI for cruising, although there are people interested in do this with low water injection rates--the so called 'lean cruise' folks that are trying to run AFRs of 20:1.
Suffice it to say if you want economy out of a 2 or 2.5 L engine you'll need a CR or 10:1 or more. You can have that and a turbo, but you'll need to either run less boost or have some pretty fancy valve-cam system to drop the dynamic CR when on boost.
Old 01-26-2006, 09:10 AM   #13
ShawnRS
Member#: 18797
MY06 WRX Wagon
Yes sorry I wasn't clear. I am taking cruising down the highway at 100km/h (speed limitish) with maybe a couple bursts of speed (over th whole tank of gas).
Thanks all
Shawn
Better gas milage? kwikside General Community 22 12-12-2008 04:15 PM
im flabbergasted!!! better gas milage! zmaster General Community 49 07-12-2007 01:51 PM
i got better gas milage from a spoiler??? ovedrivex Texas Impreza Club Forum -- TXIC 58 05-30-2007 09:24 AM
Royal Purple = better gas milage ronan1975 Service & Maintenance 4 11-20-2006 04:54 PM
Drive like a drunk and get 30% better gas milage! RightyTighty General Community 96 09-19-2004 08:40 PM
