Old 01-25-2006, 12:48 PM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Unhappy EJ20G+ej18 wiring= no spark
So im all done with my swap except i got some problems.
im using my stock ej18 engine harness, and main harness. i made my own ignition harness and have everything all hooked up. however im not getting spark. all the wires are hooked up to where they need to, power for coils, ecu to module, ect. all my cam and crank and all that other stuff is off the ej18. i re pinned my ecu connectors into ej20g ones and pluged them into the ecu. im getting fuel, and all the other stuff, but am stumped.
if anyone has ideas, throw them out.
thanks
kirill
snowman4us is offline   Reply With Quote
Old 01-25-2006, 12:57 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
What are you doing for an ignitor?
Old 01-25-2006, 03:05 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
which cam sensor are you using ?
Old 01-26-2006, 01:09 AM   #4
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
actualy got it figured out. had to run the #3 wire from the ign mod to ECU and provide it with a ground.
for ignition i made my own harness using parts from the EJ20G engine harness, and making my own harness going from engine to ign. mod. and from ign mod to ecu.
all in all i had to make about 3 or 4 harnesses that the EJ18 didnt have.
and im using ALL stock EJ20G engine sensors/componets. all i did was repin the ej18 wiring harness into ej20g plugs so they would go into the ej20g ecu. i also had to add about 15-20 additinal wires into the clips that the ej18 didnt have.
just got the car started tonight and still have a couple more things to do. i got a CEL so i can track it from there what i didnt hook up correctly.
overall this sucked BAD. it was about 4 days of wiring prep work and wiring total. my .o2 is that you use the EJ20G harness.
kirill
scoobydorift is offline   Reply With Quote
Old 01-26-2006, 03:49 AM   #5
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
*double take* you have 2 nasioc accounts?
Natoe is offline   Reply With Quote
Old 01-26-2006, 11:06 AM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
no, i was at my buddies house. and was to lazy to log out.
ej20g no spark GregBolby Pre-2002 Factory Turbo Powertrain 2 07-25-2009 07:33 PM
ej18/ej22t hybrid no spark Fail Wagon Normally Aspirated with bolt-on Forced Induction Powertrain 82 08-23-2008 09:06 PM
EJ20G - no spark scoobyimprza Pre-2002 Factory Turbo Powertrain 10 01-16-2008 12:54 AM
96 brighton 1.8l impreza 1-2 spark 3-4 no spark WRXR1A10 Normally Aspirated Powertrain 6 12-28-2007 03:52 PM
no spark & no fuel = no start Annoying Eric Normally Aspirated Powertrain 7 08-30-2005 09:58 AM
