Old 01-25-2006, 03:57 PM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default STG2 STI's, what IDC are you seeing 5500+ w/ ~16 tapering to ~15psi by redline?
I installed a typhoon and it seems to read ~+.05v above 5500 bringing my past idc's of 95-97% to 104-106%, car has just tyhoon short ram, catless tbe and accessport... with my boost curve up there what idc's are you seeing at what afr?
overdose is offline   Reply With Quote
Old 01-25-2006, 06:00 PM   #2
entropy138
Member#: 87446
2005 STI
3 second start club
Back when i had just the tXs short ram and invidia dp (stock catback) on the stage 0 and stage 1 utec maps I was seeing over 100% idcs... AFR's were originally in hte 10.3-10.4:1 range and after leaning out to 10.9-11.0:1 I was still hovering right on the 99-100%++ idcs.... There just isn't much room on the stock injectors unfortunately...
entropy138 is offline   Reply With Quote
Old 01-25-2006, 11:33 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
There's an old thread somewhere in the 2.5 forum with a log of a stock STI tune with 99% IDCs. That's all you get out of those injectors.
Old 01-25-2006, 11:47 PM   #4
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
I was maxxing out my injectors above 6000RPM's at 15psi and 11.2:1AFR. I recently installed a walbro fuel pump and my IDC's went down to about 94-95%. For $100 it gives you just enough head room for a Stg2 STI.
SloRice is offline   Reply With Quote
Old 01-26-2006, 11:51 AM   #5
Davenow
Member#: 23676
around 68% or so IIRC. Ill look later. Its no higher than 75% I know that.
Old 01-26-2006, 11:55 AM   #6
SloRice
Member#: 44351
2004 Mitsubishi Evo
^^Stock injectors? What is your fuel pressure at to make the injectors perform that big??
Old 01-26-2006, 02:05 PM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
I can't believe Dave has stock injectors.
Old 01-26-2006, 03:04 PM   #8
edmundu
Member#: 54672
I have a '05 LGT, but it is effectively running a STG2 STI setup(vf39,manifold,TMIC,dp/up,Custom PDX AP). With MAFv=4.68-4.70, I see inj duty cycles of 106-116%! This was logged using EcuExplorer if it matters...
edmundu is offline   Reply With Quote
Old 01-26-2006, 03:11 PM   #9
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Yeah guys, when you are reading 99% on the IDC, it is NOT as much fuel as they can flow. They will keep increasing pulse width until the IDC is in the 115% range.
nhluhr is offline   Reply With Quote
Old 01-26-2006, 03:15 PM   #10
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
I'm running 104% on the stock injectors at 11:1 AFRs. No problems. And YES ... for those reading this ... I DO have Walbro fuel pump installed. The pump makes no difference!
t
WolfPlayer is offline   Reply With Quote
Old 01-26-2006, 04:27 PM   #11
SloRice
Member#: 44351
2004 Mitsubishi Evo
Old 01-26-2006, 06:45 PM   #12
Davenow
Member#: 23676
Stock injectors
Stock fuel pressure
No RRFPR.
One secret weapon.
Old 01-26-2006, 07:03 PM   #13
Freon
Member#: 88322
2009 BMW 135i
Today I read about 90% @ 11:1 @ 5250rpm @ 4.4V MAF @ 16.7psig on a 45F day
... as read by a UTEC. Stock pump and injectors.
Freon is offline   Reply With Quote
Old 01-26-2006, 11:22 PM   #14
SpaldingSpeed
Member#: 83640
2005 Impreza WRX STi
World Rally Blue Pearl
Originally Posted by Davenow
Stock injectors
Stock fuel pressure
No RRFPR.
One secret weapon.
um....Alky?
SpaldingSpeed is offline   Reply With Quote
Old 01-26-2006, 11:25 PM   #15
Davenow
Member#: 23676
Originally Posted by SpaldingSpeed
um....Alky?
And thats at 20PSI btw
Old 01-27-2006, 10:13 AM   #16
SloRice
Member#: 44351
2004 Mitsubishi Evo
well, that's cheating
Old 01-27-2006, 12:56 PM   #17
bboy
Member#: 56468
04 Improved STI
Dirty White
I want Dave's secret weapon.
Old 01-27-2006, 06:51 PM   #18
entropy138
Member#: 87446
2005 STI
3 second start club
I agree - mine dropped 3-4% idcs with the addition of the walbro. Granted I didn't document all conditions like WolfPlayer but I was seeing over 100% from about 4500 on up and after the pump I could get into the 6500 range without ever seeing over 97-98... about 6500 it lost it tho. Maybe wolfplayer's FPR held up to the added pressure a bit better then usual?
Then again its easily arguable the a 3-4% drop isn't really an improvement - but it does constitute a 'difference'
What band are you truly upset that you will never see live? Neek Off-Topic 231 11-11-2009 01:40 PM
For those of you w/ RA gears, what 60 ft. times are you seeing? blue04 Proven Power Bragging 5 04-24-2004 04:05 PM
Who is racing 16 X 8's? What wheels are you using? zoomfactor Tire & Wheel 0 01-10-2004 06:21 PM
What EGT's are you seeing with Probe in uppipe Hypnotic Perf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-22-2002 04:36 PM
What EGT's are you guys with Stage 0 are seeing?? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-28-2002 02:09 PM
