Old 01-25-2006, 08:05 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Starter problem
Another problem here, let me give you some background. I'm using an Optima red top located in the trunk.
My starter is having problems working fully on it's on. Even with a battery charger hooked almost directly to it, it will only click forward, not try cranking the car. I know the starter is good; I took it right off of my car. The ground from the battery is grounded right against the starter. My positive wire is ran right from trunk to the starter and then off the starter to the fuse box.
I've gotta think I have enough power right to the starter. What could it be?
Brent
scoobyimprza is offline   Reply With Quote
Old 01-25-2006, 11:42 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
what gauge wire do you have running to the starter?
subbyspeed is offline   Reply With Quote
Old 01-25-2006, 11:50 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Very very large gauge. Not sure exactly, but it's larger than 8.
Old 01-26-2006, 05:56 AM   #4
thahaminator
Member#: 22738
Do some voltage drops across the circuit and hopefully that will give you something..
thahaminator is offline   Reply With Quote
Old 01-26-2006, 06:05 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i had 0 guage running to my starter and the it BARELY started in the winter and i am also running an optima red top. I'll never put my battery in the trunk again.
Old 01-26-2006, 11:15 AM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I'd really like to have it up front but I ran my intercooler pipe right thru the battery tray.
Old 01-26-2006, 12:53 PM   #7
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
you know that i have the same problem. but i did the conversion with the 5spd to 6spd on a GC8. i have a red top optima in the trunk. i also notice that the starter motor is sperated at the bottom of it's flange. i tried to tap a hole for the bolt but the tap striped. what i did was tried to tap the starter motor back into place and i hadn't had a problem since. the next time i have that problem, i will tap on the starter again until i drop the tranny or pull my engine out for the new engine. i'll fix it then.
old_duwel is offline   Reply With Quote
Old 01-29-2006, 10:48 PM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
So I put the battery in the front and it still does it.
What now?
Starter problems turns into locked up engine problem Minnesota1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-05-2007 07:03 PM
starter problems aschnell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2003 10:33 PM
('93-'01) '98 obs starter problem geepondy Impreza Forum 2 07-01-2003 06:51 PM
Starter problem 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 11:30 AM
Starter Problem darkangelgrafix Warranty Issues & SOA Problems 3 09-18-2002 10:28 AM
