Old 01-25-2006, 09:45 PM   #1
rkmac
Member#: 105965
Default 2.0L WRX Turbo on 2.2L Outback
Have opportunity to buy a compete turbo system off of a 2.0 WRX engine. Am thinking of buying it and putting it on my 2.2L Outback engine. Has anyone done this? What are the pros and cons? How much has to be changed? Any info or direction to look would be awesome.
rkmac is offline   Reply With Quote
Old 01-25-2006, 09:47 PM   #2
rkmac
Member#: 105965
Old 01-25-2006, 11:14 PM   #3
GrinderAK
Member#: 87551
97 OBS, 01 RS
2014 SWP FXT
my 97 obs is getting a 2.0 wrx swap, i had the opportunity to get a turbo system for the stock ej22e but was heavily advised against it. ive heard from people with experience that say the na engine will become very unreliable with forced induction. imo save your money for the swap, and take a big step up in aftermarket support, reliability, just not in displacement
GrinderAK is offline   Reply With Quote
Old 01-26-2006, 11:09 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
check out the aftermarket forced induction forum .. it can be made to work
but i won't recomend it
Old 01-26-2006, 02:10 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not as cheap or easy as it may seem at first. Need to change the crossmember to the turbo one. You need all the turbo intake plumbing and not just the uppipe, downpipe, intercooler and turbo. You also need to address coolant and oiling for the turbo, which will all be custom work.
Uniquemotorsports makes some parts to make it easier and avoid changing crossmembers. But unless you have plans to put a dedicated turbo engine in there later, none of it is worth the effort, IMO. You are better off buying a kit from FAT, or finding a used PDM, LudeSpeed, etc kit on E-bay or in the classifieds. Replacement EJ22's are cheap if you pop it.
We are about to start a project with a PDM turbo kit with VF-23 turbo on an Ej22E. But that will be for shorterm fun while we build an Ej257 bottom end with SOHC Ej25 heads. And full standalone EM is on the agenda as well. Figure another grand or so for the EM...
Old 01-31-2006, 03:04 PM   #6
kheff46
Member#: 66739
2002 WRX wagon
had that setup, and it worked well. basically it was rs power at 7ish psi. above that is a problem without proper EM. but you can do it, been there done that! swapping v4 sti as soon as it arrives. but you can do it under $500 if you can scrounge parts well. i did it for $70 piping, adapters, lil stuff like that(had turbo,ic, etc. to start) you can do it easily, search around you'll find the info needed round here! -keith
kheff46 is offline   Reply With Quote
trying to work out a stock wrx turbo on 2.5 rs? Rtony103 Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-21-2006 04:41 PM
stock wrx turbo on 2.5 rs? need some help Rtony103 Subaru Conversions 3 10-18-2006 02:32 AM
FS: 2.0L WRX Turbo Motor complete ComTekAuto Private 'For Sale' Classifieds 0 04-24-2006 06:51 PM
2 Stock WRX turbos on a 3000 GT VR-4 vr4_rider Newbies & FAQs 31 06-01-2004 05:54 PM
factory wrx turbo on 2.5? chinaman Normally Aspirated with bolt-on Forced Induction Powertrain 13 03-12-2003 01:07 PM
