Old 01-25-2006, 11:00 PM   #1
Evothisbitch
Member#: 73139
2004 WRX
Default my 16" barely fits.
I've got 16" Sparco Tarmac on GD. It went in w/o a problem but once it's on, the space between rim and brake is tight as a virgin's ass. When I tried to drive, it's rubbing. Now the question is if I drive it, will the caliper eventually dug deep enough groove so it the rim and brake won't contact anymore? I'm just talking about a couple of millimeters.
Evothisbitch is offline   Reply With Quote
Old 01-26-2006, 12:06 AM   #2
horf
Member#: 35971
2002 WRX wagon
I'd be really careful about this. You might damage the caliper. And the grinding on the wheel could comprimise the wheel, not to mention the heat that will be generated when rubbing. You should spring for 17" rims to be safe.
horf is offline   Reply With Quote
Old 01-26-2006, 12:08 AM   #3
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
run a spacer
svek is offline   Reply With Quote
Old 01-26-2006, 01:56 AM   #4
Evothisbitch
Member#: 73139
2004 WRX
care to explain?
currently it's 16x7 w/ offset 50.
Old 01-26-2006, 02:45 AM   #5
svek
Member#: 82259
1999 impreza 2.2L
well, i know to tuck wrx wheels on 4pots you run a spacer to make the rim stick out further (either lower offset or wider rim) basically you make it like hte stock RS 16x7 rims. so by running a like a 3 or 5mm spacer i think would get the rim off the caliper so its safe...assuming i interpreted this correctly
Old 01-26-2006, 03:17 AM   #6
NW OBS
Member#: 101361
05 OBS
Obsidian Pearl Black
Originally Posted by svek
run a spacer
+1. Get the proper spacer....
NW OBS is offline   Reply With Quote
Old 01-26-2006, 10:55 AM   #7
Jim Lewis
Member#: 92551
2005 Saab 9-2X
I'd prefer slightly filing the caliper versus running a spacer for several reason, mostly safety.
Jim Lewis is offline   Reply With Quote
Old 01-26-2006, 11:26 AM   #8
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
If you even got the wheel to move, it's <1mm, not 2-3mm. Figure out the actual interference. Also, do you have brand new brake pads? With a sliding caliper, caliper-spoke clearance changes with the brake pad thickness.
If it's really <1mm of interference and your pads are new, you can shave the caliper or grind down the brake pads with a belt sander. If your pads aren't new, you've got even bigger problems and should get wheels that fit.
Jon Bogert is offline   Reply With Quote
WTB: 16" bare stockies, CNTRL/ESTRN VA SOOBNUT Private 'Wanted' Classifieds 0 08-12-2008 09:57 AM
(soCal) Want to trade my 16" Legacy GT whls for your 16" Subaru steelies? FujiHeavyFreak Private 'Wanted' Classifieds 1 12-02-2004 11:45 PM
FS: A set of 4 16" steelies - fit WRX H5N1 Vancouver Impreza Club Forum -- VIC 1 10-20-2004 08:02 PM
Rota 16" Slipstream fit WRX? dazz1 Brakes, Steering & Suspension 8 04-16-2002 07:45 PM
?WRX 16" rims fit on 1998 Outback Sport??? moltibici Brakes, Steering & Suspension 5 10-23-2001 03:35 PM
