Old 01-25-2006, 10:22 PM   #1
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
Default Amplifier Issue *please read*
I have an Alpine CDA-9847 and i jsut bought an Alpine MRPT-100 amp. and i hooked the amp up to the yellow(battery) wire and the blue/white (remote) wire coming out of the head unit for the remote and pwer connections on the amp. Then i jsut sanded some paint off in the truck drilled a hole in it and put my ground wire there. But when the car sits for a long time (4 hours or more) without it running, then when i put my faceplate on the amp and head unit jsut blink on for less than a second and turn off and repets that for about 10 mins then it will finally turn on. This happen to anyone else? Any ideas?
circaisdashiat is offline   Reply With Quote
Old 01-25-2006, 10:25 PM   #2
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
the amp is drawing too much current. you should always run the power wire for the amp directly to the battery using a fused wire. you probably could get away with it being powered off of the 12v wire in the ignition harness because it is a small amp. but the best way is direct to the battery.
you have the remote turn on and the ground part right. you just need a suitable power source for the amp
thedaddyb is offline   Reply With Quote
Old 01-25-2006, 10:35 PM   #3
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
ok will do, thanks!
Old 01-26-2006, 01:10 AM   #4
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
not to be an ass, but why would you hook up constant to the battery off the radio?
vipernj is offline   Reply With Quote
Old 01-26-2006, 08:43 AM   #5
circaisdashiat
Member#: 96315
1995 STi V5 replica
World rally blue
i dont know cuz it was easyist, cuz i have my wireharness back there connect to the radio with wire nuts, so i can just take the wire nut off add the other cord and put it back on. Ive never done this before so i thought that it would work, but aperently not.
OBD readiness issue- specific function readiness- please read mpaone Engine Management & Tuning 36 07-06-2014 07:11 PM
Please Read!!! Issues with AMS in west chicago, IL 03SuBbYWrX Mid West Subaru Owners Club Forum -- MWSOC 61 12-14-2007 03:10 PM
*ATTN* Safety issue when using CUSCO rear swaybar on a STI. Please read!! Dynamispeed Southern California Impreza Club Forum -- SCIC 29 03-08-2004 11:18 AM
Please read:2002 vs. 2003 boost issues randolph-rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-03-2003 01:13 PM
Warranty Issue ??? Please read... MKULTRA General Forum Archive 15 05-24-2000 12:06 AM
