Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 01-25-2006, 04:13 AM   #1
Member#: 105927
Default late 1980s Subaru Ignition questions
Hi Folks,
I need some information (schematics) on the old distributor + coil ignition system from the early '90 legacy EJ18.
I recently fitted a 1990 Legacy N/A (carb) EJ18 engine into a project car.
The project car does not have a suitable wire loom for this engine, so I'm making a temporary loom to make the engine run.
I have fuel but no spark; the engine ran before I removed it from the Legacy.
I followed the wires before I removed the engine,
there are 2 wires to the coil, one a yellow, ( 12V+ supply, I think) which also feeds to the the distributer, then to a capacitor. The other coil wire is black/blue+red which also goes to the distributor, (changes to black/white at connector)
the black/blue wire comes (as does the yellow) through the bulkhead from the inside of the car.
I want to figure out where this black/blue+red wire connects inside the car. (Before removal, I cut this wire just outside the bulkhead, with the engine running, and it didn’t stop!, so I assumed I would NOT need it, I thought it was just for tacho)
I have the yellow conencted to +12v, yet I don't have a spark at the plugs, but it did with the black/blue+red wire cut??
This is confusing me some, If I had a schematic I could maybe figure this out
This ignition circuit is probably found on other models form late '80s, early '90s
Thanks for any help.
dancn is offline   Reply With Quote
Old 01-25-2006, 09:36 AM   #2
Member#: 5218
96L Most Over-
Developed Beater
You might wanna try www.ultimatesubaru.net
There is a world of Subaru knowledge within that community. Specifically the earlier models.
Jay Storm
Old 01-25-2006, 12:25 PM   #3
Member#: 28990
are you in the US? cause if you are then we never got the dist EJs, and I don't think any EJ was ever carb'd from the factory. now if you're talking about loyales, then it would be EA82.
JWX is offline   Reply With Quote
Old 01-26-2006, 03:53 AM   #4
Member#: 105927
No it’s a European carbed EJ18.
Problem solved anyway.
Both the coil and the dissy have a round 2 pin plug. On the dissy and coil there are 2 wires a yellow and a black-white. On the loom there is a yellow (12v+ IGN) and black–blue ( - ).
When I looked at the loom closer on the donor legacy, I spotted that the switched 12v+ yellow on the loom, does NOT go to the yellow on the coil or dissy. The yellow goes to black-white, the black-blue goes to yellow.!!!
Swapped them around, hey presto the engine fired up 1st time
1980 Subaru GL EA71 1600 Misfire 4x4subieguy 'Old School' Subaru Forum 0 04-21-2010 12:26 AM
Subaru Ignition System jetskibucky Newbies & FAQs 3 03-17-2008 01:50 AM
1980 subaru gl wagon FOR SALE!!!! righthandsti 'Old School' Subaru Forum 3 12-25-2006 08:37 PM
pre 1980 subaru dj00crusty Subaru Conversions 1 06-01-2005 10:04 PM
1980 Subaru GLF5 spt_impreza Canada Region Forum 7 02-14-2003 08:45 PM
