Old 01-26-2006, 08:59 AM   #1
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Default will 93 legacy 5spd ecu work on 95 impreza after swapping 5spd into impreza?
I found a 5spd 93 legacy awd and wondered if I would have to take my ecu (my car is automatic fwd) and change it to the legacy 5spd ecu? I would like to make sure I don't fry the ecu and keep cruise control stuff as well. Are the pinouts the same?
2slofouru is offline   Reply With Quote
Old 01-26-2006, 06:28 PM   #2
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
why legacy ecu when you haev a full impreza setup already?
seems random
swapstar is offline   Reply With Quote
Old 01-26-2006, 07:59 PM   #3
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Well I read on some dude's awd swap writeup that he had to put in a standard ecu and remove the auto one. Then there were so many wires he had to cut and splice and rig relays and stuff. The legacy ecu wouldn't work anyway, I checked it today and it's actually a 95, they had the car marked incorrectly. It was an obd2 ecu anyway, I can't use, different plug. My 96 impreza donor car is also obd2, so I can't use it, that sucks. Now I need a obd1 standard ecu. I don't want to fry my auto ecu trying to rig it. Want to save time as well.
Old 01-26-2006, 08:03 PM   #4
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
i know i used to have one somwhere. i didnt give it to you?
Old 01-26-2006, 08:07 PM   #5
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Nah, you sold that one before I realized I might need it. I'm slow in the membrain.
Old 01-26-2006, 10:10 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
What ECU do you currently have?
The info I have says the 95 Impreza ECU does have an AT/MT identifier pin. If that's true, you should be able to do the same thing I did with my swap and make your AT ECU work.
Check out the electrical portion of my swap write up
www.surrealmirage.com/subaru/swap
Legacy777 is offline   Reply With Quote
Old 01-26-2006, 10:34 PM   #7
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I have the auto ecu. I did read your writeup, it seems to involve a lot of cutting and splicing. I am aware of the identifier pin on the ecu, I noticed it while researching how to connect my emanage. Your write up seems to say that for my situation I'd have to modify wiring for the cruise control, reverse lights, the relay that prevents cranking without the clutch pushed in, etc. I can do all these thing I guess, but I thought it would be more plug n play. I didn't know my impreza had a tcu either. The boxes under my driver side are tiny compared to the one you showed in your write up.
Old 01-28-2006, 07:34 PM   #8
Legacy777
Member#: 4800
Yes, you will have to do the wiring modifications. The only way around it is to swap the entire wiring harness.....which is a FAR more laborous task if you ask me.
will a 2002 wrx ecu work on a 2003 wrx? scoooby03 Engine Management & Tuning 4 09-11-2011 03:14 PM
Will 93 Legacy front axles fit a 94 Impreza? ZZcorollaVV_Ti Transmission (AT/MT) & Driveline 4 03-18-2008 11:34 PM
Will STI Accessport 2.0 work on a Legacy 2.5GT (2005)? RobSub AccessPort 4 07-28-2007 08:18 AM
Will a 95 Legacy Auto Tranny Work On A..... 8820jimbery Normally Aspirated Powertrain 0 03-21-2006 08:21 PM
Would 93 ej22 ecu work on 93 ej18? maxim Subaru Conversions 4 10-26-2004 04:20 PM
