#1 |
Member#: 21764
RMIC
Vehicle:Some GDM V8, JDM Flat 4 X2 |
anyone know the exact diff, between the GC(wrx) and GD crossmembers. i did my swap and i su[osedly got a gc cross member, but the front crontroll arm bracket was about 1/2 inch to wide.
sorry if this belongs in susp. forum. also could comeone post up pic. of both of them for comparison. thanks kirill
#2 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
If it is too wide, it's a GD x-member. Go to the hardware store and get some shims to put in there. I am pretty sure Squeech includes the measurements in his write up on his cardomain site...
http://www.cardomain.com/ride/693496 |
#3 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
Yup, that pretty much IS the only difference.
#4 |
Member#: 30695
Vehicle:BOOM , Get her to sew THAT! |
![]() Top: 2004 STi Bottom: 92 Legacy Turbo Depending on the year of the Impreza/Legacy it's coming out of there is a difference in the way the sway bar mounts. I believe the cut off is -97 for bolt/tab and 98+ for bolt/nut. |
#5 |
Member#: 832
RMIC
Good point. If you are using a USDM WRX member, you need the sway bar and mounts to go with it...
#6 |
Member#: 76785
Vehicle:2000 RSTi Coupe SRP |
so the 98+ lgy member will be a direct replacement in the RS and you can use a WRX sway bar?
#7 | |
Member#: 16274
Vehicle:2001 GM6 2.0L vf30 e30 black/rust |
there is no 98+ legacy turbo crossmember, at least not here in the states.. You need the early 90's legacy turbo.. I can't remember the year off hand, but i believe it was the 91 and 92?? Its what i have on mine.. Its a direct swap onto the RS. But you will need a different front swaybar, i've read the wrx front bar will work, but i went with the cusco front swaybar thats designed for GC turbo cars. found here: http://www.z1auto.com/prodmore.asp?m...ling&prodid=48 |
#8 |
Member#: 76785
what about the 04-05 LGT crossmember?
#9 | |
Member#: 832
RMIC
top of page 3 if you go looking for it... ![]() |
#10 |
Member#: 21764
RMIC
yeah, its a gd x-member. i already thought about the washers, and thats what im going to do.
and yeah, i got the sway bar with it. and my x-member had a weird brace on it, it was all stock looking and just connected to 3points total. anyone know if that is on all the gd x-members or sti, ect... thanks of the pic. ![]() |
#11 |
Member#: 44581
BAIC
Vehicle:3 Boxers 2 AWD 3 turbo 1 6cyl & a 13BT |
Depends on the brace. If it was on top of the jacking plate it was only on 04 STi, if it was part of the jacking plate it's on all 05+ Impreza. That doesn't apply to jdm though.
| Thread Tools | |
| Display Modes | |
| Handling? GC vs GD | wswhatever | Newbies & FAQs | 22 | 12-12-2005 11:34 AM |
| GC vs GD front control arms. | S.G.D | Brakes, Steering & Suspension | 2 | 07-18-2005 02:41 PM |
| GC vs GD who's owned both? | Silver '02 REX | Impreza Forum | 4 | 08-26-2004 03:58 PM |
| GC vs GD | Impreza01 | Bay Area Impreza Club Forum -- BAIC | 10 | 10-26-2002 11:22 AM |
| Full Turbo Kit GC vs. GD differences | Imprezer | Factory 2.0L Turbo Powertrain | 1 | 06-27-2002 12:22 AM |
