Old 01-26-2006, 11:54 AM   #1
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Question JDM ECU paired with US ECU - pro & cons
Noticed on some vendor sites where they pair the ECU's. It sounds like it would be a good thing, if it really works.
Has anyone heard good or bad about this?
cjfike is offline   Reply With Quote
Old 01-26-2006, 12:17 PM   #2
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Pair? As in run both ECU's at the same time?
mrbell is offline   Reply With Quote
Old 01-27-2006, 12:06 AM   #3
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Yes. A site I visited had this wiring harness which brought both ecu's into play. It was unclear how they interacted, engine control was coming from the original JDM ecu.
Old 01-27-2006, 12:17 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no bad idea
Old 01-27-2006, 09:14 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
got a link?
Old 01-27-2006, 09:40 AM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
That is pretty useless unless you have a system that is unable to be flashed, and have to replace it's fueling/timing abilities with that of a standalone.
'Bad idea' is putting it nicely.
Old 01-27-2006, 10:04 AM   #7
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
I am unclear as to the actual benefit of this. Anyone have some insight as to why this is done?
RickInLittleElm is offline   Reply With Quote
Old 01-27-2006, 10:40 AM   #8
Freon
Member#: 88322
2009 BMW 135i
The only reason I can see to do this would be if you did a full factory stock JDM swap, but needed to pass US emissions.
I have toyed with the idea of using a second ECU to control extra devices, like WI/alcohol injection, once all the free flashing tools are working well. The stock ECU is very powerful, its just a matter of being able to make it do what you want.
Freon is offline   Reply With Quote
Old 01-27-2006, 10:42 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ok ill expand the only place its a good idea is something like mine
the stock ecu is running the fuel pump relays creating the tach signal turning the fans on and off
i have second ecu (tec2) and second crank sensor that control the fuel and spark functions
it works ok .. but its not my daily driver
Old 01-27-2006, 11:10 AM   #10
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Passing emissions is certainly a positive. Although bad idea was my first thought also, emissions was the thing that came to mind. Still I cannot imagine how one ECU could control the engine, and the other would just be controlling US emissions compliance. Unless it is simply powered up and waving it's arms screaming "I AM OBD-II"!
Old 01-27-2006, 11:54 AM   #11
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
You probalby wouldn't pass emissions. You have two options with this, really. One, trying to drive 2 ECU's w/ one set of sensors will certainly throw 'Circuit High' codes all over the place. Or disconnect the US ECU from the sensors, and then you get 'Circuit not ready' codes all over the place. If your county does OBD-II testing, then you won't pass with these codes. If they don't do OBD-II testing, you dont' have to worry about it anyway.
Old 01-27-2006, 01:34 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
there is nooooo way it will pass obd-2 emmissions zero
if you don't have to do obd-2 just run the jdm ecu ...
Old 01-28-2006, 12:12 AM   #13
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
COOL beans man!
How would one go about asking the county if they do OBD-II testing? I guess I could walk into a test center and ask. Fairfield CT is a very odd place. Backward in alot areas you would not expect; then on the cutting edge of what you don't expect.
JDM EJ25 vs USDM EJ25, pros & cons ? qtr_wrx Subaru Conversions 9 05-25-2009 12:10 AM
Using JDM heads/cams with US sensors/ECU, heres how... Invisiguard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 08-20-2006 12:19 PM
The End of the Cold War & the Disintregration of the USSR... pros & cons? Asinine Political Playground 14 10-07-2004 07:17 PM
Aftermarket clutch & LWFW - Pro & Cons STi4life Transmission (AT/MT) & Driveline 3 03-17-2004 10:17 AM
Fuel pump on a N/A: pros & cons please Evil-Mastermind Normally Aspirated Powertrain 5 03-08-2001 08:50 AM
