Old 01-26-2006, 12:44 PM   #1
styng88
Member#: 55541
05 Saabaru
96 Miata
Default My electric meter is making a loud noise
My house was built in 1989, so I'm assuming that the electric meter is original. Lately, it has been making an odd noise, sort of a cyclic hum that is loud enough to be heard in the two rooms that are the closest to it. It started out being very infrequent, but latley is constant. If I go outside and beat on the glass, it goes away for a small period of time, but always seems to return. Should I call the utility company? If so, will a newer, more efficient meter make my bill higer?
styng88 is offline   Reply With Quote
Old 01-26-2006, 12:46 PM   #2
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
Yeah, call the Utility company. Its coil could be going.
imprezton is offline   Reply With Quote
Old 01-26-2006, 12:47 PM   #3
Buckeye Kid
Member#: 41369
2002 Subaru WRX
It's a bomb.
Buckeye Kid is offline   Reply With Quote
Old 01-26-2006, 12:47 PM   #4
Blknblu
Member#: 29188
Chapter/Region: PRSIC
2000 Ducati M900
RUN!!! It's going to assplode!!!
Blknblu is offline   Reply With Quote
Old 01-26-2006, 12:51 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Unlikely.
KD7000 is offline   Reply With Quote
Old 01-26-2006, 12:54 PM   #6
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
Seriously, though, it's probably just that the torque of the movement over time has loosened the screws that fasten it. They might just need to retighten everything. But let them do it. You don't want an inspector driving by and seeing you "tampering" with the meter.
Old 01-26-2006, 06:23 PM   #7
bajabob
Member#: 73236
2003 Baja
Baja Yellow
Definataly call utility and have them check it out you might have a loose connection on one of lugs inside of the meter. If you smell a burning plastic smell stay away from it cause it would suck to be nearby if all the power in your neighborhood decided to cut loose in the meter.
Bob
bajabob is offline   Reply With Quote
Old 01-26-2006, 06:32 PM   #8
Rich Yankowski
Member#: 105949
04 WRX STi-repo'd
Platinum
Call the utlity company A.S.A.P.. The meter pan on my house caught on fire a few years ago and if the neighbor hadn't spotted it, I might be living elsewhere!
Rich Yankowski is offline   Reply With Quote
Old 01-26-2006, 06:34 PM   #9
gerbs
Member#: 41597
Originally Posted by Buckeye Kid
It's a bomb.
gerbs is offline   Reply With Quote
Old 01-26-2006, 06:34 PM   #10
UCI_Scott
Member#: 5088
Evacuate! Evacuate! It's gonna blow!!
UCI_Scott is offline   Reply With Quote
Old 01-26-2006, 06:37 PM   #11
bmxdave
Member#: 92425
2008 WRX Sedan
Unplug the sexbot.
bmxdave is offline   Reply With Quote
Old 01-26-2006, 06:37 PM   #12
avk
Member#: 17252
'06 WX8
59E
Check for any new wires going out of the switch box to your neighbors, or to a trailer recently parked nearby.
avk is offline   Reply With Quote
Old 01-26-2006, 06:51 PM   #13
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Worst case scenerio the lugs or meter tabs in the meter socket are frying...
is there any smell or sizziling?
just call & tell the utility to send a meter tech to look or swap out the meter.
if the meter socket is toasting you may need an electrician to swap out the guts & wires.
Meter sockets last a long time... (unless some n00b did the install)
better to find out BEFORE you burn off a leg, or worse the neut.
GLwagon is offline   Reply With Quote
Old 05-21-2007, 08:08 PM   #14
styng88
Member#: 55541
05 Saabaru
96 Miata
I just got a letter from the Power company saying they changed my meter. Last month my bill was just under $24, and the last two months it kept going lower, and lower. A year and a half later, it finally gave out.
Old 05-21-2007, 08:17 PM   #15
enkd
Member#: 15376
2002 WRX Wagon
2016 Forester
cool, thanks for the update - I haven't gotten much sleep for the past 16 months.
enkd is offline   Reply With Quote
Old 05-21-2007, 08:20 PM   #16
styng88
Member#: 55541
05 Saabaru
96 Miata
Sorry for your loss.
Old 05-21-2007, 08:35 PM   #17
platinum05
Member#: 104904
05 Evo Mr
Shart Fast
hay i read meters all friggin day! great job, just walk around, hang out with peoples dogs and work on my farmer tan. Meters going bad usually won't make noises though, they just gradually just stop working. a broken meter will never make your bill go up, that would mean it worked, just too well. It will just mean that it will show as if you have used less and less useage and then the system will catch up send someone out to swap meters and a computer will give an estimate on how much you will owe by estimation i believe. just call your service provider.
platinum05 is offline   Reply With Quote
Old 05-21-2007, 08:44 PM   #18
rice h8r
Member#: 94524
your electric bill is under $24??? wtf?
rice h8r is offline   Reply With Quote
Old 05-21-2007, 09:05 PM   #19
enkd
Member#: 15376
2002 WRX Wagon
2016 Forester
You know, I'm almost sad to see it come to an end. Kind of bittersweet, though. I hope you saved a picture of the old meter in the family bible.
* Help my boost gauge is making a buzzing noise ultraspdWRX Electrical & Lighting 17 06-11-2011 10:22 PM
My '98 OBS is making a funky noise maharashii Transmission (AT/MT) & Driveline 9 03-06-2007 06:19 PM
my engein is making really loud ticking noise!! sjtangb21 Normally Aspirated Powertrain 28 04-06-2005 10:19 PM
hi-flo cat make the loud noise? Imprezive2002 Normally Aspirated Powertrain 5 05-13-2003 12:03 PM
Help! My car is making a loud noise! GooseMan Normally Aspirated Powertrain 13 08-29-2002 06:04 PM
