Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 01-26-2006, 06:24 PM   #1
kn0bby8
Member#: 97644
2006 WRX
Default Delta dash
I am looking to get some gauges for my car. I will probably end up with egt, boost, and oil pressure. I am not a big fan of all the different gauges in the pillar and else were.
I really like the psi3 or the delta dash. the delta dash seems to be cheaper than the psi3 and from what i have read you can do more with it.
I have a cobb ap will delta dash work with my car?
will i be able to moniter EGT, boost, and oil pressure? will extra sensors be needed?
is there any advantage to having traditional gauges over the delta dash.
kn0bby8 is offline   Reply With Quote
Old 01-26-2006, 06:41 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You could get the Ecutek Dash Display unit-
http://www.ecutek.com/products/dashdisplay/
However for readable boost monitoring you are better off with an analog gauge, watching a needle sweep is much easier than rapidly changing numbers on a digital display. For oil pressure you will need a separate gauge anyway, the ECU does not monitor oil pressure. The EGT readout from the ECU isn't what you want either, even if the stock probe is still in place in the uppipe. You'd need an external EGT probe.
You could also get the standard Delta Dash product and set it up with the virtual dashboard, but you'd need a PC and screen permanently mounted in the car.
Old 01-26-2006, 09:40 PM   #3
jim1969
Member#: 34877
2005 Legacy GT sedan
talk to Bill at North Coast Subaru in Glen Cove. He sells the EcuTeK monitor and can answer your questions. You should hook up the boost, oil pressure and oil temp senders to the unit. I say boost because even though the unit can read it from the ECU, the ECU only reports to like 18.3 psi. So if you spike above that you'll still only see 18.3psi.
jim1969 is offline   Reply With Quote
WTB: Ecutek Dash Display and Delta Dash disk singincanary Private 'Wanted' Classifieds 0 08-31-2007 02:03 PM
Pull through 3rd - Delta Dash basline mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 05-14-2002 06:04 PM
ECUTEK Delta Dash rules! fastburro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 63 05-08-2002 03:03 AM
Delta Dash Vegumkoho Rocky Mountains Impreza Club Forum -- RMIC 0 05-02-2002 06:34 PM
Delta Dash meets Dawes at 19 PSI on MY99 std ECU/turbo/intercooler john banks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-23-2002 05:16 PM
