Old 01-26-2006, 10:18 PM   #1
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Default Brake Math/Torque Spreadsheet
I may have posted this before, but I've had some time to go through the spreadsheet and clean things up, and make quite a bit of improvements. The biggest being a 'Brake Torque Calculator'. Let's say you want to swap some WRX brakes onto your 90 Legacy. Choose your car from the drop down menu, and the WRX as what you want to go to, and the calculator will spit out the percent change in brake torque and whether the shift is frontward or rearward.
If you don't see your vehicle in there and have information on your car, please let me know and I will add it. Likewise, if you see anything that looks incorrect or suspect, please let me know.
http://www.main.experiencetherave.co.../brakemath.xls
Josh
Legacy777 is offline   Reply With Quote
Old 01-26-2006, 11:28 PM   #2
ripvw
Member#: 27790
awesome - thanks for all the hard work...
ripvw is offline   Reply With Quote
Old 01-27-2006, 11:27 AM   #3
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Great job Josh. I have used your previous spreadsheet and it worked very well. Thanks for sharing all your hard work.
Ken
coolcougar is offline   Reply With Quote
Old 01-28-2006, 09:35 AM   #4
richde
Member#: 79498
2013 XV
Josh
The Subaru 4-pots are not an upgrade in braking power from WRX sliders according to this spreadsheet, how is that?
richde is offline   Reply With Quote
Old 01-28-2006, 10:15 AM   #5
ripvw
Member#: 27790
http://forums.nasioc.com/forums/show...&highlight=h6s
http://forums.nasioc.com/forums/show...&highlight=h6s[/quote]
Old 01-28-2006, 01:09 PM   #6
richde
Member#: 79498
2013 XV
[/quote]
Wow, thanks for turning on the clue light!
Old 01-28-2006, 01:39 PM   #7
REX8
Member#: 24038
I guess you know already from reading...
Piston size is down...you give up a little power over the 02-05 2-pots...but gain it back in rearward bias and significantly better braking feel.
Old 01-28-2006, 07:31 PM   #8
Legacy777
Member#: 4800
You're welcome guys. Please let me know if you see any errors in the caliper piston size or rotor data.
Also, if you have any other MY's that you know, please let me know, and I will add them.
Old 02-14-2006, 12:08 AM   #9
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
Josh, I like this version much more.
Here's SVX data if you want to add it: http://www.subaru-svx.net/forum/showthread.php?t=29007
rotor OD is 302mm front 290mm rear
THAWA is offline   Reply With Quote
Old 02-14-2006, 08:53 AM   #10
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
the STi only has 2 pot?
Brake Data >> Subaru Brake Caliper Piston Diameter Data >> 04 STi listed twice
...i think i may be reading it wrong
and the 1995 L AWD, does that have abs or not, and originally equipped with a rear drum?
psyber_0ptix is offline   Reply With Quote
Old 02-14-2006, 06:30 PM   #11
Legacy777
Member#: 4800
Thanks Hardy.
I'll add it to the brake info section. I don't think I'll add it to the part where I calculate brake torques since the SVX calipers are not swappable onto other subaru models. At least that's what I've understood. Correct me if I'm wrong.
Old 02-14-2006, 06:43 PM   #12
Legacy777
Member#: 4800
The STi Brembro's are definitely 4-pots. The reason it's listed the way it is, is because the pistons are not the same size. The trailing piston is smaller then the leading piston. The reason it's like this is because there is a self-energizing or wedging effect of the pad. By staggering the size of pistons, you include this effect into your calculations, and the resultant setup provides a more equal force distribution from front to rear of the brake pad.
There was a lot of different configurations for the 95 Impreza. The configuration I give is for 4-wheel discs. The calculation is much more complex for drum brakes, and since I don't have all the information needed, I don't include options for drum brakes. The only model that had 4-wheel discs was the 2.2 liter LX, and it had ABS standard.
I will add that clarification to the spreadsheet.
Josh
Old 02-14-2006, 08:21 PM   #13
Legacy777
Member#: 4800
I posted a question in that thread. Can you answer it?
Old 02-14-2006, 09:03 PM   #14
THAWA
Member#: 44581
3 Boxers 2 AWD
Thanks Hardy.
I believe they're swapable. I know the rear calipers are as they are the same exact calipers used on all the other cars with the same size piston (90-94 Leg wagon, Turbo, RS, GT, etc). The bracket is similar to 00-04 legacy except it's designed for the old style of pads. The fronts I believe have the same mounting pattern, but I'll verify that next time I take off the wheels.
Old 02-15-2006, 09:03 AM   #15
Legacy777
Member#: 4800
Yeah it was the mounting pattern of the bracket is what I heard was different....but maybe not. Since the SVX has such large brakes, I would have figured if they were swappable, people would be using them....
Old 02-15-2006, 09:37 PM   #16
THAWA
Member#: 44581
3 Boxers 2 AWD
You'd have to find discs to match, remember 5x114.3mm.
Old 02-18-2006, 09:20 PM   #17
Legacy777
Member#: 4800
Ok....that's what was different.
Old 02-18-2006, 09:27 PM   #18
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
um i get a your port 8080 is borked...
OvrClkdPmp is offline   Reply With Quote
Old 02-21-2006, 05:22 PM   #19
Legacy777
Member#: 4800
Try again,
If it still doesn't work, try this
https://www.mail.experiencetherave.c.../brakemath.xls
Old 01-18-2007, 05:19 PM   #20
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Stoptech 4pots + 328mm rotor?
I thought we knew the piston diameter for those?
jblaine is offline   Reply With Quote
Old 05-26-2008, 09:01 PM   #21
abacall
Member#: 132025
06 WRX Spec-C Swap
No options for Foresters..
I don't know that data offhand.
abacall is offline   Reply With Quote
Old 05-27-2008, 01:59 AM   #22
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You know, I really want to thank you for writing the spreadsheet. I downloaded it a year or so ago and it's really useful. It's full of stuff that a lot of people can't wrap their heads around so it's a good thing it's getting a bump.
Old 05-27-2008, 03:32 AM   #23
Back Road Runner
Member#: 60082
2004 Forester STI
The Forester uses Impreza stuff, so 02 and ealier uses Impreza sedan parts. The 03 steps up to the WRX front rotor and becomes increasingly front biased (dumb). That's all.
I can only assume the change to the WRX front rotors was to aid with heat dissipation and braking when towing, although, I hate messing up the bias more. They should have just thrown on the larger Outback rear rotors when they upped the front ones, it's a much better setup, helps more with heat, braking, and actually neutrals out the bias.
Awesome spreadsheet Legacy777!!!
I don't know if I'd worry too much about the Forester setup, but you can add it if you want. Older Impreza setup front and rear. In 03 with the redesign, the front went to the larger WRX rotor, still small Impreza rear, at least for the XT model. I have no clue about the NA models if they were also upped to the WRX front rotor. The brake booster and calipers are just the Impreza stuff, so nothing fancy there. I have no clue about the new 08 Forester though...
Old 05-27-2008, 03:44 AM   #24
jamal
Member#: 71875
98 Legacy GT
my wheels fit
well, we don't know if the prop valve changed, plus if the car has ebd it doesn't really matter as much.
jamal is offline   Reply With Quote
Old 08-18-2009, 11:33 AM   #25
nmalinoski
Member#: 220192
2009 WRX, WR Blue
Is there any data for Impreza WRXs newer than 2005?
nmalinoski is offline   Reply With Quote
sti brake caliper torque qingshan Brakes, Steering & Suspension 8 05-11-2006 08:21 PM
Engine braking and torque distribution Mind Transmission (AT/MT) & Driveline 2 04-14-2006 12:48 PM
Brake math thread Legacy777 Legacy Forum 7 01-28-2006 07:46 PM
Master Cylinder sizing, brake pedal dead area, brake math Legacy777 Brakes, Steering & Suspension 26 10-24-2002 12:51 PM
Wanna help me do some brake math? Jon Bogert Brakes, Steering & Suspension 23 06-11-2002 10:07 PM
