Old 01-27-2006, 10:28 AM   #1
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Default head bolt question??
I'm installing an STI 2.5l on RS heads. I want to know if the tightening sequence and torque specs are the same as the DOHC heads? I believe so but I want to make sure.
Thanks,
Jose
Pacobeagle is offline   Reply With Quote
Old 01-27-2006, 11:36 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
techinfo.subaru.com
Old 01-28-2006, 05:14 AM   #3
PlatinumRex
Member#: 22810
2002 WRX Drag Car
Best E.T. 9.842 @ 148
its the same on all DOHC. I would recommend using head studs from ARP. We use them on all the engines we build and have yet to blow a head gasket. The factory bolts are stretch bolts so, if you run alot of boost they will stretch.
-Mark
PlatinumRex is offline   Reply With Quote
Head bolt question PSolbergfan Built Motor Discussion 14 11-23-2009 04:50 PM
Head Bolts Question kleen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-11-2007 01:01 PM
Stupid cylinder head bolt question - 14mm x 12-point socket? root Built Motor Discussion 3 07-03-2007 08:56 PM
question about 02 wrx head bolts Subynut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-31-2007 12:29 AM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 08:30 AM
