Old 01-27-2006, 12:03 PM   #1
dukeduster
Member#: 95789
2002 WRX PTE
6262, hydra, 1100 FIC
Default cobb ap with utec
Hello i was wondering if before i install my utec i need to clear the ecu form my previous accessport programming? would it make a big difference or ??
dukeduster is offline   Reply With Quote
Old 01-27-2006, 07:15 PM   #2
dukeduster
Member#: 95789
2002 WRX PTE
cmon now 23 views and no answers i thought this was a engine managment section
Old 01-27-2006, 07:23 PM   #3
02Toyowrx
Member#: 56520
i guess you arent getting answers because what you are doing doesnt make sense. The AP is far superior over the UTEC.
02Toyowrx is offline   Reply With Quote
Old 01-27-2006, 07:26 PM   #4
dukeduster
Member#: 95789
2002 WRX PTE
how is a cobb accessport better than a TXS Utec? i can just plug my laptop in and start ripping away at the fuel and timing curves! on my cobb accessport i have limted maps to choose from! My question is do i have to take off the cobb accessport map from the ecu before i install my utec? please enlighten me. I am just learining here
Old 01-27-2006, 07:29 PM   #5
dukeduster
Member#: 95789
2002 WRX PTE
i dont want to come off rude i just need some help!
Old 01-27-2006, 07:36 PM   #6
Gfunk720
Member#: 42549
E92 BMW M3 Wht/Blk
2011 VW TDI Wagon
Buy a streettuner and you can do the same thing. If you research, UTEC utilizes a MAP vs a MAF system and is a little different, though it is hard to say that one is better than the other. Although you can tune without any additional software, its irrelevant if you dont know what you are doing. If you cant read your data logs, having access to your fuel and timing curves is pointless
But to answer your question, yes you need to remove your AP before installing the UTEC. Simply plug in your accessport and unmarry the unit from your ECU following the directions in your manual
Gfunk720 is offline   Reply With Quote
Old 01-27-2006, 07:38 PM   #7
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
I would probably unmarry the AP before using the UTEC to be safe.
sandwi54 is offline   Reply With Quote
Old 01-27-2006, 07:39 PM   #8
dukeduster
Member#: 95789
2002 WRX PTE
Thanks a lot guys i do appreciate it! i can read the fuel curve maps and timing is a little tricky for me i like to base my fuel from my a/f and knock so i kinda know about that a little.
Old 01-27-2006, 10:17 PM   #9
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You can run AP under the UTEC. Just remember if the AP is scaled for larger injectors than the UTEC will not need injector scaling. The AP is just like running an EcuTek under a UTEC. The UTEC will control timing and fueling as normal once over the TPS crossover.
And folks remember that apart from a couple of features all aftermarket EM's do the same sort of thing. They allow you to change the stock params. It's the tuning that produces the power, not the different EM. Of course some allow easier control than others.
mick_the_ginge is offline   Reply With Quote
Old 01-27-2006, 10:26 PM   #10
MrH00nel2
Member#: 80474
2003 4088R
Twin Scroll
where do you get this info from?
anyway...i would clear the ap from the ecu (un-marry like that one guy said) if you are going to use the utec. unless you know what you are doing. you can use both if you wanted too
MrH00nel2 is offline   Reply With Quote
WTB Cobb AP or UTEC r0nzar Private 'Wanted' Classifieds 2 07-09-2006 04:49 PM
Cobb AP vs. UTEC ALaDDiN Newbies & FAQs 48 12-17-2005 04:48 PM
0k, another cobb ap vs utec... jam69007 Engine Management & Tuning 12 11-28-2005 01:00 PM
COBB AP or UTEC? yoojeankim Engine Management & Tuning 3 08-14-2005 08:44 PM
Question about Cobb AP & Utec Way2Slow Engine Management & Tuning 1 01-02-2005 10:15 PM
Message Board Statistics All times are GMT -4. The time now is 02:44 AM.
