Old 01-27-2006, 12:05 PM   #1
Zumble
Member#: 34860
2005 Forester CGM
Default Determining safe EGT for your motor?
Is there a way to determine what the maximum safe EGT temp is for your specific motor? Everyone has different tuning, slightly different probe mounting points etc. I've done some searches and the consensus seems to be 1600F is the magic maximum number. My car will reach 1700F in a 5th gear WOT run. My probe is installed in the front passenger side runner in the manifold. I'm wondering if there is a way using data logging to determine if 1700F on my Defi gauge is actually safe for my motor?
Zumble is offline   Reply With Quote
Old 01-27-2006, 12:55 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
If there were a specific test, it would be destructive. The 1600 number you have is the lore. RiftsWRX, I believe, has run his own car to 1700 for many miles of hard driving. It's the valves you have to worry about. I kind of remember Jorge being of the mind that less timing gets the heat out of the cylinder faster--reducing knock initiation, but at slightly higher EGT.
Old 01-27-2006, 01:09 PM   #3
Zumble
Member#: 34860
2005 Forester CGM
I bumped my warning up to 1700 per Jorge's advice but I saw 1800 on a pull once. I was just wondering what other variables are in play. I guess you're right that a test of the max limits would be destructive. The car still seems happy even after seeing 1800. What makes me nervous are all the 1600s being thrown around. I was thinking 1600F may be the temp that stuff starts melting or something.. =P But like I said, my car sees 1700 on 5th gear pulls and it's fine. So something to keep in mind for future people looking for the magic EGT number.
WTT: My Greddy White 60mm EGT for your Temp. CKxx Interior/Dressup/Audio & Security 11 08-12-2009 11:20 AM
Look here for oil coolers to help keep your motor safe! MastroWRX Engine/Power/Exhaust 20 02-28-2006 04:07 AM
Where do you tap your sensor for your EGT ScoobyDooo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-13-2006 11:47 AM
I feel sorry for your mothers. NOT WORK SAFE OLMEK Off-Topic 26 11-11-2003 11:04 AM
How do u determine the SEX of your Car??? AWDBOY Newbies & FAQs 2 02-07-2002 12:10 PM
