Old 01-27-2006, 01:58 PM   #1
IvanWRX
Member#: 106107
2003 EJ207 STi
Rally blue
Default Inmobilizer
Hi,
I wonder if someone can help me with the following
A friend is selling me his EcuteK reflashed ECU, his car is exactly like mine, the ECU numbers are the same, but we are having problems with the exange because of the car's inmobilizer. My car with his ECU installed won't start.....is there any chance of making it work?? Is there a way to "baypass" the inmobilizer??
IvanWRX is offline   Reply With Quote
Old 01-27-2006, 02:13 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Exactly what make/model/year car are you talking about?
Jon [in CT] is offline   Reply With Quote
Old 01-27-2006, 02:13 PM   #3
Zumble
Member#: 34860
2005 Forester CGM
You can take one of his spare keys and hide it under your dash. Or you can go to the dealership and pair his ECU with your car.
Originally Posted by IvanWRX
Hi,
Zumble is offline   Reply With Quote
Old 01-27-2006, 02:19 PM   #4
IvanWRX
Member#: 106107
2003 EJ207 STi
Rally blue
My car is a Subaru Impreza WRX 2003. If I hide one of his spare keys under my dash, won't the inmobilizer get confused by the two codes (his key under the dash and my key trying to start the car??
Old 01-27-2006, 02:24 PM   #5
Zumble
Member#: 34860
2005 Forester CGM
I didn't know 2003 WRXs has immobilizers.. And no, your car will just look for the right key. Your key with mechanically turn the ignition cylinder and the spare key will let the ECU know you have a correct key. It should be fine but I'm still confused that you have an immobilizer. Worst case scenario is you make a new key to start the car with and keep your friend's spare key under the steering wheel. Should probably flatten the teeth of your friend's key or cut it off completely if you do this.
The correct way would be to go to the dealer and get this sorted out though.
New engine, inmobilizer problems? tharoka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-14-2005 09:57 AM
