Old 01-27-2006, 03:56 PM   #1
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
Default UTEC Stg 4 Map w/FMIC & Intake
does anyone have this???
gcm05 is offline   Reply With Quote
Old 01-27-2006, 04:08 PM   #2
gcm05
Member#: 105948
someone?
Old 01-27-2006, 05:14 PM   #3
gcm05
Member#: 105948
to the topage
Old 01-27-2006, 05:27 PM   #4
POS_WRX
Member#: 69447
2002 Stage 4 WRX
yeah.....you're going to need to post more info than that
POS_WRX is offline   Reply With Quote
Old 01-28-2006, 02:38 AM   #5
gcm05
Member#: 105948
ok i need the stg 4 with a 34 on 93 oct with an aps cai, bov, and aps725 fmic
Old 02-03-2006, 12:32 PM   #6
gcm05
Member#: 105948
anyone????
Old 02-03-2006, 01:12 PM   #7
AaronWRX
Member#: 7194
2011 997.2 Turbo
Originally Posted by gcm05
anyone????
turboxs used to have a stage 4 fmic base map. It looks like they dont anymore. So this is what you do, you load the normal stage 4 base map: http://turboxs.com/downloads/utec50stg4.txt
then you use your laptop, wbo2, and EGT gauges to reach the target boost, make fuel adjustments, and add some timing to the map to take advantage of your fmic.
AaronWRX is offline   Reply With Quote
Old 02-03-2006, 01:14 PM   #8
gcm05
Member#: 105948
thanks
Old 02-03-2006, 01:18 PM   #9
AaronWRX
Member#: 7194
2011 997.2 Turbo
here are some tips on that stage4 base map... make the boost values in the 90% colomn and 100% column the same.
Also.. add about 18 degrees of timing in the 0% column from abtou 4750 rpm on up to 7250. This should prevent shift knock.
Old 02-03-2006, 01:19 PM   #10
gcm05
Member#: 105948
alright...thanks again
Cash for your UTEC stg 4 - VF22 map wrspssshhhh UTEC 0 03-24-2006 12:07 AM
looking for a utec stg 4 map reconracer Engine Management & Tuning 2 08-13-2005 10:01 PM
Base utec Stg 4 map occasional knock help! boost4life Engine Management & Tuning 5 05-21-2005 11:25 AM
Anyone running Vishnu Stg 1/stg 1 MAP w/ FMIC quickgtp Engine Management & Tuning 0 06-09-2004 10:35 AM
TXS UTEC Stg. 4 map vs. Stg. 4 map w' TMI? S-1 Engine Management & Tuning 2 10-24-2002 06:24 PM
