Vancouver Impreza Club
Old 01-27-2006, 05:08 PM   #1
razy
Member#: 82124
05 WRX (SOLD)
aspen white
Default what does it take for a wrx to beat a STi?
discuss
for off the line and at higher speeds
debating what kinda setup i should go
razy is offline   Reply With Quote
Old 01-27-2006, 05:10 PM   #2
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
You can't "make an STi" out of a WRX.
For more power just put in a bigger turbo and all the supporting mods. This should cost you less than the price difference between the two cars.
Of course, you still won't have the suspension, brakes, interior, etc, etc.
-J
Jitenshakun is offline   Reply With Quote
Old 01-27-2006, 05:14 PM   #3
razy
Member#: 82124
05 WRX (SOLD)
aspen white
i know..but im talking about just beating it in general..
i heard with uppipe, downpipe, exhaust, boost controller, and a STi top mount properly tuned you can catch up to a STi no problem?
Old 01-27-2006, 05:15 PM   #4
innova
Member#: 97472
2005 PDX STi
Aspen White [email protected] woot
Yea that's true but it probably won't last as long.
And remember, you can mod an STi also
innova is offline   Reply With Quote
Old 01-27-2006, 05:16 PM   #5
razy
Member#: 82124
05 WRX (SOLD)
aspen white
i know :P talking about stock STi here haha
Old 01-27-2006, 05:23 PM   #6
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Ask Jamie
Edit: In my old RS-T, I was able to be neck and neck with a stock 04 STi until about 120km/hr then he pulled on me.
fukamoto is offline   Reply With Quote
Old 01-27-2006, 06:11 PM   #7
red_soul_D
Member#: 43554
04 red dub
SRR
i would say don't be a minimalist....the better supporting mods you have the more effiecent and reliant your power gains will be
...plus you don't want to be overworking so many stock components
FUKA: you paced w/ an sti in your rs-t??? i have to see to believe
red_soul_D is offline   Reply With Quote
Old 01-27-2006, 06:23 PM   #8
patr
Member#: 97
there are lots of WRXes that can keep up and keep away from a stock STi.. but it just takes the right mods and the right driving (keep it in the boost). Saying they wont last as long is very misleading - equally maintained and setup I will go as far to sugest that the STi will fail first on the rod bearings ! Its doesn't take that much and you dont need to do anything to the internals. Its not just engine, ratios will help you here too.
but from standing starts, the WRX suffers from the tranny.
patr is offline   Reply With Quote
Old 01-27-2006, 06:24 PM   #9
supermarkus
Member#: 6971
2008 WRX STi
SSM
srt-4 ftw!!!
supermarkus is offline   Reply With Quote
Old 01-27-2006, 06:35 PM   #10
5ive0
Member#: 68369
2004 SRT4, MB C36
Originally Posted by supermarkus
srt-4 ftw!!!
actually we prefer "teh fast3R!!!1"
5ive0 is offline   Reply With Quote
Old 01-27-2006, 06:40 PM   #11
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Yup. I launched it at about 3500rpm right off boost and it jumped. The stock clutch slipped on 1st and a bit on 2nd. Then at about 3rd gear redline (in my car), the STi pulled on me....and it pulled hard.
End of the day, yeah, you can easily build a WRX to take over a stock STi. But I'd much rather start from scratch with a 2.5L turbo'd motor than a 2.0L. Even if you were to stroke the WRX motor to 2.2L, it'd be pricey and...well, I'd much rather start with a STi and build upwards.
Old 01-27-2006, 11:30 PM   #12
tony_subaru
Member#: 22742
I've seen guys dump a ton of money into NA 2.5's and 2.0's. They perform well, but the sti just gives such more variety to get more power. If you want the power with all the goodies best bet is an sti. The wrx at stage 2.5 for example will stay ahead of an STi (from experience). But, remember the wrx has longer gears and only a 5spd which gives it a bit of help (less shifting) on straight line dragging. You can't make up for the torque that an sti puts out though. But if you compare a wrx to a sti in dragging, a wrx with turbo upgrade, bigger injectors, exhaust and a good tune will be quicker than a stock sti. But then again, a modded wrx vs a stock sti in autocrossing, track racing etc... will have a different outcome for sure.
tony_subaru is offline   Reply With Quote
Old 01-28-2006, 01:44 AM   #13
slowguy
Member#: 4326
i know what it takes to beat a WRX that can walk a stock STI
but that WRX has since gotten faster
slowguy is offline   Reply With Quote
Old 01-28-2006, 02:19 AM   #14
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
no matter what you do the tranny will be your limit, it doesnt take much to get 300+ hp but you need to be able to stop properly and get the power to the ground. The engine can take 300+ but you will likely blow your tranny shifting hard trying to keep up with the STi.
-K
ps like J said an STi is more than a motor it is all the supporting things.
Chp_Stix is offline   Reply With Quote
Old 01-28-2006, 03:47 AM   #15
tony_subaru
Member#: 22742
-K
04+ WRX's tranny's have sti RA width gears which should withstand 300hp. The 06 wrx even have stronger trannys supposodly.
Old 01-28-2006, 03:52 AM   #16
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
06 WRX is the same tranny as the LGT i heard the otherday, just hearsay so i dont know but seams stronger
Old 01-28-2006, 01:53 PM   #17
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
I'm assuming you mean drag type racing. You would need a minimum VF30-34, all the good pipes, and the fuel and tuning to make it all work together to beat a stock STi. You also need to know how to drive, while supporting brake and suspension mods would help too.
That's a stock STi though. Once he mods, it's all out the window.
steve is offline   Reply With Quote
Old 01-28-2006, 02:32 PM   #18
fukamoto
Member#: 13339
2014 SWP WRX Wagon
STi RA gearset cyro treated should be able to withstand the power...
Old 01-28-2006, 04:31 PM   #19
feiron
Member#: 62327
2005 WRB STI
[S600BY]
I dont know where you get this information from. But even the dealership confirmed that WRX tranny are the some from 02-05. The only difference is in the syncro (someone need to confirm this) for 04-05.
I'm not so sure about the 06 though
feiron is offline   Reply With Quote
Old 01-28-2006, 06:01 PM   #20
LastResort
Member#: 99289
SOA is wrong all the time when it comes to that kind of information, just ask Jamie about H6 upgrades and break clips. The computer says the same clips for all WRX's if you look it up individually, but Jamie opened a 02 break kit box and an 05 break kit box (I believe) and they had different parts in them.
LastResort is offline   Reply With Quote
Old 01-28-2006, 06:19 PM   #21
Solar
Member#: 79825
2000 Impreza 2.5 RS
White body + carbon hood
ej257 shortblock and supporting mods + ppg gearset and supporting mods + weight reduction = $$$$, but should be very fast in a strait line. Braking and cornering will be another exspensive formula.
Solar is offline   Reply With Quote
Old 01-28-2006, 06:24 PM   #22
Doulik Industries
Member#: 84754
wait, I think i read somewhere on one of the local forums that you said you had a STI motor?
go to the second page
http://www.vancouverxchange.com/forum/read.php?t=40517
Doulik Industries is offline   Reply With Quote
Old 01-28-2006, 07:01 PM   #23
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
do a JDM Sti swap.. ultimate goal imo.. (only works on bugeye though, cuz there is no point in swapping on the new body since it does come with the STi version)..
KIMUTAKU is offline   Reply With Quote
how long does it take for money order to get to the seller? MadDogSTi General Community 15 05-02-2006 01:47 PM
What does it take for the R180? ReX_N Transmission (AT/MT) & Driveline 3 02-19-2005 08:24 PM
After shaving how long does it take for your beard to grow back? wrxfx Off-Topic 33 08-12-2004 03:28 PM
STi with 6 speed tranny... what does it mean for the WRX warranty? Porter Warranty Issues & SOA Problems 12 01-09-2003 11:12 AM
what does it take for a sedan front lip to fit wagon? Benjamin Tang Interior & Exterior Modification 8 06-28-2002 02:31 PM
