Old 01-27-2006, 09:52 PM   #1
SubyDan05
Member#: 92860
02 wrx
yellow
Default using fuel cut
im using fuel cut for the launch control, and whenever im hitting the launch control limiter for about 5 seconds at 4600, the check engine light flashes right after. i think that it is misfiring because that is what the code came up as last time. since then after i go past about 5000 rpms it sounds like i am hitting a limiter but i think it is misfiring. i think the plugs may be bad. any ideas?
SubyDan05 is offline   Reply With Quote
Old 01-28-2006, 10:03 PM   #2
SubyDan05
Member#: 92860
02 wrx
yellow
im answering my own question. the flat shift was set at 5500. i didnt know what flat shift was
hks fuel cut....60 shipped never used vatorn10 Engine/Power/Exhaust 7 11-27-2006 12:09 AM
HKS fuel cut defender?? are you using it? trboCIVIC&WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-07-2003 08:09 PM
Hitting Fuel Cut and Boost cut at 18 PSi HELP!! ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-11-2002 10:36 AM
Boost cut and fuel cut- same thing? 1984 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-05-2002 07:06 PM
