Vancouver Impreza Club
Old 09-18-2001, 04:04 AM   #1
IN WALK TURTLE
Visiting NASIOC Timeout
Member#: 1264
1998 2.5 RS
Rally Blue
Default groung wire
GOOD EVENING GUYS,
i install the ground wire into my car and it does good job on it why i know that? because i notic that when i put into the 3th gear when slow going it damn good.( c west modle)
trust me wo wu.
it is now so famouse in japan.....
IN WALK TURTLE is offline   Reply With Quote
Old 09-18-2001, 04:18 AM   #2
jacktam1
Member#: 1783
2000 2.5RS
just read the acticle from the HK car mag. tonight, they had the test regarding the ground wire, it's roughly 0.1-0.4 V increased after installed the new ground wire.
HKD$700 for it.
how much you bought it for?
jacktam1 is offline   Reply With Quote
Old 09-18-2001, 04:42 AM   #3
IN WALK TURTLE
Member#: 1264
1998 2.5 RS
Rally Blue
hk $700
howmuch is that in can?
Old 09-18-2001, 05:08 AM   #4
jacktam1
Member#: 1783
2000 2.5RS
CAD$140
u got it for??
Old 09-18-2001, 05:13 AM   #5
IN WALK TURTLE
Member#: 1264
1998 2.5 RS
Rally Blue
can $135
Old 09-18-2001, 05:18 AM   #6
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
I guess this is not just a wire then ...?!?!
Where does it attach?
Necromancer is offline   Reply With Quote
Old 09-18-2001, 05:21 AM   #7
IN WALK TURTLE
Member#: 1264
1998 2.5 RS
Rally Blue
it is simple just wires and and the trangle conect to the wires and to the box engin but i think it is expensive
Old 09-18-2001, 01:58 PM   #8
sandy lam
Member#: 2498
1999 Impreza 2.5RS
RBP
Where can I read about this??? Any pic of how this look like??
sandy lam is offline   Reply With Quote
Old 09-18-2001, 02:39 PM   #9
jacktam1
Member#: 1783
2000 2.5RS
HK option fans volume.42
Old 09-18-2001, 03:00 PM   #10
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
They had it advertised in the new products section at Taka Kaira not too long ago. I even posted it up in the NA forum...a lot of guys say that it's basically hocus pocus. It works yes, but to pay that much money I don't think it's worth it. You can achieve the same effect if you do it yourself with wires and stuff.
Keiho is offline   Reply With Quote
Old 09-18-2001, 09:55 PM   #11
bender
Member#: 1839
hey keiho, the link doesn't work for me. it takes me to a "hosting controller" which saids I need a password
bender is offline   Reply With Quote
Old 09-18-2001, 10:04 PM   #12
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
The site must be down then. Oh well.
Old 09-18-2001, 11:51 PM   #13
sandy lam
Member#: 2498
1999 Impreza 2.5RS
RBP
oh no.. i only have volume 41
Old 09-19-2001, 12:46 AM   #14
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Someone explain this to me. I still don't get it...
Ken is online now   Reply With Quote
Old 09-19-2001, 03:04 AM   #15
IN WALK TURTLE
Member#: 1264
1998 2.5 RS
Rally Blue
it is very easy to do it like DIY......i know how to do it and just go around the electronic shops and buy the thick wires and conecter...that is it and also 3 bolts.
Old 09-19-2001, 03:44 AM   #16
Avenger
Member#: 1234
I think the concept behind this is with a bunch of grounds connected from the engine to the body or battery, will cause it to have less resistance between the engine and the body/battery. With the decrease in resistance the sensors and other electrical equipment attach to the engine will recieve more power due to the decrease in resistance. So with more free power the alternator does not need to work as hard, putting off some load off your engine.
But I don't think you'll feel any big difference.
Avenger is offline   Reply With Quote
Old 09-19-2001, 09:36 AM   #17
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Does it not have to do with improving spark propagation? Because if the block is well grounded (negative field), then there is a larger voltage difference between the positive spark and the ambient air ==> bigger spark.
I thought this was only necessary for fooked up, repaired cars that have front ends made of Bondo.
Old 09-19-2001, 10:54 AM   #18
Avenger
Member#: 1234
hmmm.. bigger spark hmmm.... I guess it really depends on what the spark consist of. Never really thought about it.. Well Voltage = Amperage x Resistance. If resistance goes down then I guess it would make a bigger spark. But this might be the case on regular distrubitor ignition vehicle becuase the spark jumps to ground.
On our car it uses DIS which have a waste spark side (+ spark and - spark). The positive spark comes out one side of the coil pack through the spark plug wires and plug then travel through the engine and reverse the fire of the spark plug back into the wires and to other side of the coil pack. So I doubt it would work too well for our car..
Enought info for your brain Joe?
Old 09-19-2001, 10:58 AM   #19
Avenger
Member#: 1234
Hahahaha.. we actually got a Van that had a prblem with grouding.. The alternator wasn't charging.. so we stuck another ground to the vehicle after some test and it worked..
Old 09-19-2001, 01:10 PM   #20
AcIdRoX
Member#: 1021
1999 2.5 RS
Blue :)
So where on the engine block would you attach the wires to?
AcIdRoX is offline   Reply With Quote
Old 09-19-2001, 09:01 PM   #21
Avenger
Member#: 1234
I guess my post got too technical.. so everyone stop posting
Old 09-19-2001, 10:43 PM   #22
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Interesting bit about direct ignition ... but the EJ20's have coil-in-plug design so maybe that has an effect (i.e., the field around the coil being more negative or some****likethat).
If ya wanna people to post, all ya gotta do is mention something about Kelfo's love interests ... and they will come.
Old 09-19-2001, 11:17 PM   #23
Ben
Member#: 423
2002 WRX wagon
Could you post any pics on how the connection , I am interesting for DIY, since I got a roll of 8 gauge wire and a bag of gold plate stereo (-) connector. I think its thick enough for doing the ground wire , just don't know where to place the ground wire back to the battery's (-) termanal!!
Thanks for your help!!
Ben
Ben is offline   Reply With Quote
Old 09-19-2001, 11:42 PM   #24
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default Lookie what I found....
Did a simple search and look what I found by typing "ground wire"
LaterZ!
Darren!!
http://www.i-club.com/forums/showthr...ht=ground+wire
Penphoe is offline   Reply With Quote
Old 09-20-2001, 12:37 AM   #25
IN WALK TURTLE
Member#: 1264
1998 2.5 RS
Rally Blue
hi all, it does helps my 3th gear improvement lo...because befoe i dont have that; the 3th gear in slow speed is like out of gas or more likly engin lag. and now it goes smooth.
Valor its702 wiring harness xwrx07 Car Audio, Video & Security 1 06-01-2010 03:52 PM
FS: WA, 2 AMP Wiring Kit GOOD wires, BIG 3 wire kit 4bangers4life Interior/Dressup/Audio & Security 1 12-21-2009 02:33 PM
Wiring... shielding speaker wire from power wire badkid Car Audio, Video & Security 3 11-14-2003 06:53 PM
Groung wire for SAFC scoobyimprza Engine Management & Tuning 1 08-13-2003 12:52 AM
wiring question- keep the amp power, speaker wires away from input wire? garie Car Audio, Video & Security 5 06-20-2003 06:25 PM
