Old 01-28-2006, 09:18 AM   #1
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Default which clutch to use with 1.8L 5spd and 2.5 engine?
I have the 5spd from a 96L and want to put a stock replacement type that will work for the 2.5 without slipping. Should I just use a new 1.8 clutch or will I have to change the flywheel and use a 2.5 clutch? The transmission also has the cheesy cable clutch. I'd like to change it to hydraulic but I'm not sure if it's worth the trouble. Ideas anyone? I don't want to buy another transmission.
2slofouru is offline   Reply With Quote
Old 01-28-2006, 10:17 AM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
If its AWD, you can use any push type clutch.. ie. 1.8awd, 2.2awd, or 2.5rs
If its FWD, you have to use the 1.8 fwd clutch. The input shaft on the fwd tranny is smaller than the awd trannies, therefore you can't use the awd clutch.. Believe me, thats what i was gonna do, till i found out you couldn't.
subbyspeed is offline   Reply With Quote
Old 01-28-2006, 11:57 PM   #3
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
So:
-I can change it from cable to hydraulic
-I can use a 2.5 clutch on the 1.8 flywheel
The transmission I am putting in is a 5spd awd.
Old 01-29-2006, 12:02 AM   #4
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i'm not positive if the 1.8 flywheel will work with the 2.5 clutch.
Do some digging through the tranny forum, it should be there somewhere.
Old 01-29-2006, 06:08 AM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
use 2.5L fly with AWD 2.5L clutch. theres however a good chance a 1.8L fly is same bolt pattern diameter and probably is lighter.
swapstar is offline   Reply With Quote
Old 01-29-2006, 09:12 AM   #6
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
If you use an AWD clutch, you need to use an AWD flywheel. So if your 1.8 flywheel is AWD, then you can use it. The FWD and AWD pressure plates use a slightly different bolt pattern on the flywheel, but the size and mass of the flywheel are the same.
scoobyimprza is offline   Reply With Quote
Old 02-02-2006, 06:50 PM   #7
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
So I should be able to use the 1.8L awd flywheel and just buy a 2.5L clutch? Is there a certain car I can get the hydraulic master and slave cylinder from that will bolt onto the 1.8L awd transmission? Thanks for the info.
Old 02-02-2006, 07:37 PM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
Don't bother changing to a hydraulic clutch. The cable works fine and will ensure you don't have issues with shudder. Plus, you won't have to change pedal assemblies and go through the work and expense involved with all that. You can use a stock RS clutch setup or stage1 if you feel like it. I can't confirm the same bolt pattern on the 1.8 flywheel for the RS clutch. I swapped out to a light flywheel at the same time as my motorswap.
Jay Storm
Old 02-02-2006, 10:33 PM   #9
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I guess I'll use the 1.8 flywheel then. I checked on advance auto parts' website and the beck/arlney clutch part numbers are the same for the 1.8, 2.2, and 2.5, and the spline count and clutch disc diameter are all 8 and 7/8. So that means they all have the same clamping force and any one should be sufficient for the 2.5 engine as long as it's an awd clutch set?
Old 02-02-2006, 11:33 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I love my cable clutch and so do all the WRX owners who drive it. You will see the 1.8L AWD tranny has the same part numbers (aftermarket) as the 2.5RS...
do an ACT lightweight flywheel while you're in there...trust me...they're cheap too...
Old 02-03-2006, 12:07 AM   #11
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
You're safe with the flywheel as long as it's an AWD flywheel. There's no difference between those N/A AWD flywheels.
Old 03-23-2006, 11:47 PM   #12
ProjectL
Top Scoob 018
Member#: 66952
03 Wrx Wagowned
95 L swapped ver1 fmic'd
Sorry for the noob/hijacking, but would an sti clutch work with a 1.8 awd?
ProjectL is offline   Reply With Quote
Old 03-24-2006, 08:33 AM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
Not without changing the clutch actuation to pull type instead of push type. There isn't much reason to use an STi clutch with the amount of aftermarket clutches available to the RS crowd.
Which clutch disks work with stock pressure plate and 5-7psi? (td04) Anhdalai Transmission (AT/MT) & Driveline 4 08-28-2007 01:53 PM
which clutch to use??? gatwrx Transmission (AT/MT) & Driveline 2 08-13-2006 04:47 PM
which clutch to use? 2slofouru Transmission (AT/MT) & Driveline 0 02-02-2006 05:08 PM
Borla catback..and which dp to use with it..? CapeRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-19-2005 11:03 PM
Which Struts To Use With H&Rs? 1quikrex Brakes, Steering & Suspension 1 10-08-2002 08:47 AM
